Autometer and AEM Gauges- 7 Total- Like NEW! - Vintage Mustang Forums
post #1 of 3 (permalink) Old 02-09-2017, 08:05 AM Thread Starter
app01's Avatar
If you look at my build thread, you will see that I just installed a digital dash, and no longer need these individual gauges so selling them. These gauges were installed just a few years ago when I first did the restoration.
Please message me with any questions.
All of these gauges together cost $1475 new.
I have included the links to Summit Racing for each of the gauges that provide a full description and their pricing.
All gauges include the install info, sensors and wiring. All wires between the sensors and gauges are full length and uncut with factory connectors on both ends. Power and other accessory wires were shortened when installed. They are in great condition and fully function.
Prices below do not include shipping. Also only shipping to the lower 48 states and will ship FedEx insured.
I already priced things at a very good deal, however, I would really prefer to sell all gauges as a set, so buy all 7 gauges and save even more- $770 for everything saving another $50 over the individual prices below.
I have also included a few pictures showing them installed in my car as a reference.
AEM Electronics Analog Wideband Air/Fuel UEGO Gauge Kits 30-5130
2 1/16 in. diameter
AEM Electronics analog wideband air/fuel gauges unite unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM wideband gauges also offer a 0-5V analog output for use with data loggers and virtually any engine management system, such as the AEM Electronics EMS or FIC. The gauges feature a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The backlighting is user adjustable to 7 colors, (white, blue, green, red, orange, light blue, and aqua), allowing users to easily match the wideband gauge to most factory gauge clusters.
Cost new = $220 - https://www.summitracing.com/parts/avm-30-5130
Your price $120
AutoMeter Sport-Comp II Pro-Control Analog Gauges offer the same hi-def white LED illumination as the Sport-Comp II gauges and then up the ante with unbelievable features. Pro-Control gauges include an output that can control optional accessories like lights, ignition kill switches, cooling fans, or warning alarms. Sport-Comp II Pro-Control temperature gauges have programmable low and high warning points with peak recall, while all other versions have a programmable warning point and peak recall function. Pro-Control gauges are the first of their kind to put total control and driver awareness of critical engine functions into a compact, precise, and attractive package.
3652 -Sport-Comp II Pro-Control, Oil Pressure, 0-100 psi, 2 1/16 in., Analog, Electrical
Cost new =$240 - https://www.summitracing.com/parts/atm-3652/overview/
Your price $140
3654 - Sport-Comp II Pro-Control, Water Temperature, 100-260 Degrees F, 2 1/16 in., Analog, Electrical
Cost new =$190 - https://www.summitracing.com/parts/atm-3654/overview/
Your price $100
3677 - Sport-Comp II Pro-Control, Boost/Vacuum, 30 in. Hg/30 psi, 2 1/16 in., Analog, Electrical
Cost new =$240 - https://www.summitracing.com/parts/atm-3677/overview/
Your price $140
3640 - Sport-Comp II Pro-Control, Oil Temperature, 140-280 Degrees F, 2 1/16 in., Analog, Electrical
Cost new =$190 - https://www.summitracing.com/parts/atm-3640/overview/
Your price $100
3683- Sport-Comp II Pro-Control, Voltmeter, 8-18 V, 2 1/16 in., Analog, Electrical
Cost new =$155 - https://www.summitracing.com/parts/atm-3683/overview/
Your price $80
Note that since this is a voltage gauge, there is only the connector that goes into the gauge, the rest of the wiring connects to power and optional warning indicators.
3667 - Sport-Comp II Pro-Control, Fuel Pressure, 0-15 psi, 2 1/16 in., Analog, Electrical
Cost new =$240 - https://www.summitracing.com/parts/atm-3667/overview/
Your price $140
www.PalmieriConcepts.com custom showboards
10.17 @134(still practicing)
70 Mach 1 w/Boss 460 Stroker Engine-Build http://forums.vintage-mustang.com/bu...ld-thread.html
70 Boss 302-May 70, Dearborn-Build http://www.palmiericoncepts.com/My-M...970Boss302.htm
62 Corvette-Build http://www.palmiericoncepts.com/My-M...roon/index.htm
MCA, MCCNE Member
app01 is offline
post #2 of 3 (permalink) Old 03-02-2017, 06:46 AM Thread Starter
app01's Avatar
Update: What is left is: Oil Temp, Volts, Boost/Vac and Fuel Pressure gauges.
MCA, MCCNE Member
app01 is offline
post #3 of 3 (permalink) Old 03-13-2017, 05:57 PM Thread Starter
app01's Avatar
Prices lowered on what is left:
$90 - Oil Temp
$70 - Volts
$130 - Boost/Vac
$130 - Fuel Pressure
Plus shipping which US postal priority should be around $12-$15 for 48 lower states, depending upon your zip code..
MCA, MCCNE Member
app01 is offline
