68 Mustang Built - Vintage Mustang Forums
post #1 of 7 (permalink) Old 01-20-2017, 11:12 AM Thread Starter
68 Mustang Built
I sure read a lot on the forum, tons of great info. I thought it would be great to start a build thread for myself and see if I can get any input from all the smart people out there.
I'm in the middle of preparing for the AJE Colt 65 to arrive. The factory power steering valve was bad so I wasn't able to drive it. The suspension seemed shot as well. The AJE seemed like a nice solution that was future proof as well. Rack and Pinion and new suspension. Ton's of options out there, enough to make your head hurt. One thing I loved about the AJE was I could use the 351w that was already in the car and if I wanted to swap a Coyote later, it seemed to offer that flexibility. I was able to find a set of 99-04 Cobra brakes with spindles for $350 locally and my step-dad helped me refinish them while I was getting the frame rails ready for the AJE's arrival, which is seeming to take forever. In AJE's defense I did order right before Christmas. I also plan to do the electric power steering with a manual rack an pinion. I've been following some of the threads on this forum, but haven't pulled the trigger on parts yet since I still have some time. One thing I am on the fence about is the engine. I have the 351w that was rebuilt ~7000 miles ago from the previous owner in ~2006. There are some oil leaks and the pain is flaking off the block and heads. I also do not get oil in the filter, so obviously an issue. It's at a machine shop now, so that all can be corrected, but the question comes to mind of spending $3500-$4000 on a nice build for the 351w, or look at the 4.6L 3v or Coyote. Of course the latter is more expensive but will be more modern, better MPG, etc. My goal has always been the Coyote, but money is a factor.
I'll up load some pictures, starting with what the car looked like a show a few years ago, not much has changed until I dove into this project.
File Type: jpg 6216_1169485351212_1050302567_30535734_3972_n.jpg (60.5 KB, 73 views)
68 Mustang is offline
post #2 of 7 (permalink) Old 01-20-2017, 11:25 AM
Mr.E's Avatar
good looking car to start with!
1968 Mustang Coupe - work in progress
1965 Ford F100 flareside pickup - daily driver
Mr.E is offline
post #3 of 7 (permalink) Old 01-20-2017, 11:52 AM
Harleydave's Avatar
Nice project
68 Fastback.
351Windsor, 4sp, 8" 3.40 TracLok
http://forums.vintage-mustang.com/bu...ld-thread.html
Harleydave is offline
post #4 of 7 (permalink) Old 01-20-2017, 02:25 PM
Fastback Steve's Avatar
Very nice looking project you've got there. You'll find a lot of knowledge and help here.
Steve
67 Fastback
(Under Restoration)
Fastback Steve is offline
post #5 of 7 (permalink) Old 04-17-2017, 12:17 AM
luke87gt's Avatar
Let's see some more pics!
1967 Mustang
luke87gt is offline
post #6 of 7 (permalink) Old 04-17-2017, 07:39 AM Thread Starter
I have the k-member test fitting right now, that's about it. Next is to trim the rest of the towers and weld in the plates. I had some other projects come up so I haven't been able to focus on the car as much as I would like. I'm building a air compressor shelf to hod a 60 gallon I picked up and I had a new 2-post delivered that I had to install. I'll grab so more pictures and upload them.
post #7 of 7 (permalink) Old 04-17-2017, 03:39 PM
luke87gt's Avatar
I'm curious if you end up liking the kit.
As many have said, it looks to be more of a drag oriented front kit. I like that it is light-weight and gives you plenty of motor choices, but I also don't want to be holding my breath every time I hit an aggressive corner.
1967 Mustang
luke87gt is offline
