69 Coupe project. - Page 17 - Vintage Mustang Forums
 19Likes
post #241 of 257 (permalink) Old 01-15-2017, 03:45 PM
MikeG69's Avatar
Today it was in the low 40's here in south Jersey so I took advantage of the mild day & rolled the Mustang out of the garage to get a current pic & sweep out the garage.
2000 Ranger 4X4 (my DD)
1999 Explorer Sport (wife's DD)
2008 Escape (spare)
1969 Mustang Coupe (project)
Build thread; http://www.newyorkmustangs.com/forum...cs-t15096.html
AKA; mike65
MikeG69 is offline
post #242 of 257 (permalink) Old 02-11-2017, 04:30 PM
MikeG69's Avatar
Yesterday the big brown truck brought some goodies to me. 4.5 leaf mid-eye 1" lowering rear leaf springs, dual exhaust shackles, & Koni STR.T front & rear shocks.
Since it was in the low 50's today I fired up the compressor & sand blasted the used hood hinges I purchased for the 69 Coupe.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #243 of 257 (permalink) Old 02-19-2017, 08:31 PM
MikeG69's Avatar
Yesterday I purchased 2 used lower radiator saddle brackets I was missing, cleaned off the surface rust, straightened one, painted them, installed them, & installed the radiator to check the fit, looks good to me.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #244 of 257 (permalink) Old 02-22-2017, 03:19 PM
MikeG69's Avatar
Yesterday I painted the hood hinges & installed them today along with the power brake booster/master cylinder assembly & hooked up the brake lines from the distribution block/proportioning valve to the master cylinder.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #245 of 257 (permalink) Old 02-25-2017, 03:24 PM
MikeG69's Avatar
Today I was going to remove the rear axle assembly for a rebuild & replace the rear leaf springs, but I found the front leaf spring bolt is rusted to the metal sleeve inside the rubber bushing of the leaf springs. The bolts will need to be cut off to be able to replace the rear leaf springs, so that will wait for another day. Instead I installed the Koni STR T front shocks, & the hood latch support bracket.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #246 of 257 (permalink) Old 02-28-2017, 03:24 PM
MikeG69's Avatar
I set the rear of the Mustang on jack stands & removed the rear bumper & the valance so I could get at the rear shackles easier. I soaked the rear leaf spring front bolts with rust bust & put my impact gun on it & could get it to turn but it will NOT come out. Time to cut it.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #247 of 257 (permalink) Old 03-03-2017, 02:53 PM
MikeG69's Avatar
Well I did not like the Mustang sitting on jack stands under the rear torque boxes they were going to be in the way of me trying to remove the front leaf spring bolts since I have to cut the bolts to remove them. So I removed the old gas tank & placed 2 jack stands just inside the rear leaf springs & placed a 2x4 across them running under both rear frame rails & set the back of the Mustang on it.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #248 of 257 (permalink) Old 03-07-2017, 07:02 PM
MikeG69's Avatar
Removed the rear end assembly today.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #249 of 257 (permalink) Old 03-08-2017, 06:55 PM
MikeG69's Avatar
Today I removed the axle shafts & the center chunk from the rear end housing.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #250 of 257 (permalink) Old 03-12-2017, 07:21 PM
MikeG69's Avatar
Saturday I got the differential rebuilt w/trac-loc, 3.50 gears, new bearings, & new axle bearings by Alan at 8and9inchfordrears in southwestern NJ. Today I started cutting the r/s rear leaf spring front bolt.
Huskinhano and Fordrearguy like this.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #251 of 257 (permalink) Old 03-17-2017, 05:48 PM
MikeG69's Avatar
Today after work using a 4 1/2" cut off wheel on my angle grinder I cut off most of the rear leaf springs & was able to cut off the bolt end that the nut screws on to but could not get the other end because the frame is in the way. I purchased a 7" cut off wheel & made a new guard to protect my hands while cutting. I was able to cut the other end of the bolt with the larger wheel & removed what was left of the leaf spring.
Old leaf springs.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #252 of 257 (permalink) Old 03-18-2017, 08:22 PM
MikeG69's Avatar
Today I cut the l/s leaf spring front eyelet bolt & removed what was left of the spring.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #253 of 257 (permalink) Old 03-19-2017, 03:19 PM
MikeG69's Avatar
Today I removed the rear leaf spring shackle bushings in the frame rails, installed the new leaf springs, & the new spring shackles.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #254 of 257 (permalink) Old 03-20-2017, 07:35 PM
MikeG69's Avatar
Today I sanded off the old paint & repainted the rear housing.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #255 of 257 (permalink) Old 03-20-2017, 10:07 PM
looking good! New leaf springs are something I'm going to have to do soon. They're totally whipped. My wife has a 69 Grande, 351 M code. I need to get back on that. Good inspiration here!
Tom
I'm not a complete idiot, pieces are missing.
Huskinhano is online now
