69 Coupe project. - Page 18 - Vintage Mustang Forums
 19Likes
post #256 of 261 (permalink) Old 03-21-2017, 04:19 PM
MikeG69's Avatar
Originally Posted by Huskinhano View Post
looking good! New leaf springs are something I'm going to have to do soon. They're totally whipped. My wife has a 69 Grande, 351 M code. I need to get back on that. Good inspiration here!
Thanks Tom. When you do the leaf springs I would recommend using a cut off wheel & not messing with a sawzall. The cut off wheel was fairly easy to cut the bolts if yours do not come out.
Today I reinstalled the rear end housing.
2000 Ranger 4X4 (my DD)
1999 Explorer Sport (wife's DD)
2008 Escape (spare)
1969 Mustang Coupe (project)
Build thread; http://www.newyorkmustangs.com/forum...cs-t15096.html
AKA; mike65
MikeG69 is offline
post #257 of 261 (permalink) Old 03-25-2017, 08:30 PM
MikeG69's Avatar
Here is a pic of the rear end housing installed. Today I installed the center differential housing, new Koni rear STR T shocks, tightened the rear leaf spring attaching bolts, u bolts, shackle bolts, removed the old steel brake to the rear, & the old rubber brake line to the rear end housing.
Caper50 likes this.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #258 of 261 (permalink) Old 04-02-2017, 06:46 PM
MikeG69's Avatar
Today I installed the new steel brake line from the dist block in front to the rear, installed a new rubber brake hose from the steel line to the rear end housing, new steel brake lines to each rear wheel, & a new rear end vent hose.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #259 of 261 (permalink) Old 04-08-2017, 06:32 PM
MikeG69's Avatar
Rebuilt the R/S rear drum brake.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #260 of 261 (permalink) Old 04-14-2017, 09:30 PM
MikeG69's Avatar
Rebuilt the l/s rear drum brake & finished the r/s.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
post #261 of 261 (permalink) Old 04-15-2017, 08:54 PM
MikeG69's Avatar
Installed the rebuilt rear drum brakes on to the rear end housing & reinstalled the rear axles.
2008 Escape (spare)
AKA; mike65
MikeG69 is offline
