Brian's 66 coupe build - Page 24 - Vintage Mustang Forums
 29Likes
post #346 of 358 (permalink) Old 12-29-2016, 08:44 AM
I think once you get it sitting down, you will like it. If the TTD's had a little more BS, I would probably feel a little better about the 225 tire width.
patrickstapler is offline
post #347 of 358 (permalink) Old 01-01-2017, 11:45 AM Thread Starter
Caper50's Avatar
Yes that's why I'd like to get the engine and transmission in now, so the added weight can start to put some load on the springs. I spent a few hours the last 2 days cleaning all the crud off the C4. Out of curiosity I spoke to a local, well known transmission guy yesterday. I think I'm going to get him to take a look at the toploader. It got me rethinking the auto or standard thing again...not good. The older I get the more indecisive I'm getting. Anyway here are some pics of the C4.
Israel likes this.
Caper50 is offline
post #348 of 358 (permalink) Old 01-01-2017, 09:00 PM
Toploader baby...all the way.
post #349 of 358 (permalink) Old 02-02-2017, 05:43 PM Thread Starter
Caper50's Avatar
Patrick, the toploader is with the transmission guy. He says the blocker rings were seized. The transmission hasn't been turned since the 70's anyway. He has the new parts, hopefully will have it back soon. Also changing the bearings and seals. Meanwhile dug these parts out. Will have to do the Mustang Steve's bearing mod.
Caper50 is offline
post #350 of 358 (permalink) Old 02-02-2017, 09:30 PM
That a boy...I sent my WR TL tailhousing to Dan Williams this week. It was a bastard child assembly. 1966 main housing with a '70 big block tailhousing. He's swapping me the correct tailhousing. What a guy. My '65 CR TL is correct at both ends, but I didn't want to use that in my '66.
post #351 of 358 (permalink) Old 02-23-2017, 03:10 PM Thread Starter
Caper50's Avatar
Got my TL back today. Ordered a PRW flywheel and clutch fork from Jeggs. Going to use the 10.5" Ford performance clutch I picked up and ditch the 3 finger pressure plate for the diaphragm-style. Clutch pedal bearing kit on the way from Mustang Steve. Saw some posts regarding HIPO exhaust manifolds and equalizer bar issues. Does this mean the equalizer bar pictured here will not work? I have a few more pieces to pick up to complete the install.
Caper50 is offline
post #352 of 358 (permalink) Old 02-23-2017, 03:29 PM
Target's Avatar
If you don't mind my asking, around how much did it cost to have the transmission guy go over it?
I dug out a 3 speed toploader from my grandfather's backyard that was in one of my dad's Mustangs in the 80s. I'm considering throwing that beyond a '64 Ranchero with a 260 V8.
1967 Mustang 302 - Build Thread
1976 Triumph Bonneville
From Los Angeles. Going to college in Santa Cruz, California.
Target is offline
post #353 of 358 (permalink) Old 02-23-2017, 04:36 PM
Brian, I don't think the standard Z-bar will work with HiPo manifolds. Both brackets off the tube are bent different. I installed HiPo's on my car and had to install the correct Z-bar. $133.95 from NOD. Also note their site says it's made with a grease zero installed. Unless that changed within the last three months, it does not. I had to add one to mine. Easy enough to do though.
post #354 of 358 (permalink) Old 02-23-2017, 05:55 PM Thread Starter
Caper50's Avatar
Parts and labour $600
Patrick, I figured that, thanks for confirming. Last items to order are:
Throwout bearing
Pilot bushing
Clutch springs
Trying to find the right parts on RockAuto but might be easier to go with NPD.
Caper50 is offline
post #355 of 358 (permalink) Old 02-23-2017, 09:06 PM
Clutch kit usually comes with throw out bearing...mine did. And yes, I got the rest of it from NPD.
post #356 of 358 (permalink) Old 03-05-2017, 12:26 PM Thread Starter
Caper50's Avatar
Received my Mustang Steve pedal roller bearing kit.
68Hildago likes this.
Caper50 is offline
post #357 of 358 (permalink) Old 05-09-2017, 11:01 PM
66GTCoupe's Avatar
Man, it's been over a year and a half since I've been on this forum and got caught up on this thread. Nice job Brian. Anytime I need motivation to not sell my car or to continue to work on it, I scroll through this build! Looking forward to paint. I'm assuming you're sticking with the blue?
Israel likes this.
1966 GT Coupe Candy Apple Red, built 302 3 speed manual & 2015 Scat Pack Challenger.
66GTCoupe is offline
post #358 of 358 (permalink) Old 05-13-2017, 05:41 PM Thread Starter
Caper50's Avatar
Thank you 66, I haven't progressed as much as I'd hoped but little steps will get me there eventually. My work schedule was hectic for a while but should get back to normal starting this month. I was going to go with a new shifter from David Kee but a co-worker picked one up from a Canadian supplier and brought it to site for me so I saved a bunch on shipping.
Israel, Huntingky and FRC928 like this.
Caper50 is offline
