66 A code Coupe GT - Page 2 - Vintage Mustang Forums
 15Likes
post #16 of 156 (permalink) Old 02-20-2016, 05:30 PM Thread Starter
Also set the tail light panel in place to see just how well it would "fit". Glad that I ask on the VMF about NOS and Original Ford Tooling. I was about to spend about $200 bucks more than I needed to it appears...
Turnall is online now
post #17 of 156 (permalink) Old 02-28-2016, 03:15 PM Thread Starter
Didn't get a response on the VMF (before this posting anyway) about the floor cross member being straight on a '66. I feel pretty comfortable that it is supposed to be. So I straightened it out and cleaned it up and sprayed with weld-thru primer. Looks like the fit is good.
post #18 of 156 (permalink) Old 02-28-2016, 05:29 PM
Caper50's Avatar
I meant to respond but got side tracked. Mine is straight.
Turnall likes this.
Caper50 is offline
post #19 of 156 (permalink) Old 02-28-2016, 06:53 PM Thread Starter
Not finished by any means but got some spot welds holding it together. Once i finish with the spot welds, I will go back and do a few plug welds just for good measure.
post #20 of 156 (permalink) Old 02-29-2016, 06:45 AM
Caper50's Avatar
Just wondering, how big are your plug weld holes? I can't see them in the bottom of the taillight panel.
Caper50 is offline
post #21 of 156 (permalink) Old 02-29-2016, 07:39 AM Thread Starter
Brian, see picture 2 in post #17. The plan is to plug weld from the back side in the holes drilled in the cross member. I know that is a tight place to weld, but that's the plan nonetheless.
I also noticed on the VMF the one response to my question was that the bumper and tail light panel is curved. I didn't think it was...I will ask for more responses on that.
Allen
post #22 of 156 (permalink) Old 02-29-2016, 10:10 AM Thread Starter
Ok. After further review, it appears that the rear end is curved. Hopefully it can be seen in the picture I posted. "Little" things like this are obviously hard to "know" when repairing a vehicle with damage. That's the beauty of this forum!
post #23 of 156 (permalink) Old 02-29-2016, 04:49 PM
jdub's Avatar
I do not think it is supposed to be curved. Mine is, I assume from a minor fender bender.
jdub is offline
post #24 of 156 (permalink) Old 03-05-2016, 02:15 PM Thread Starter
Sunny and 64* and finishing up the tail light panel today.
Did I mention it's sunny and 64*...nice outside today!!
post #25 of 156 (permalink) Old 03-05-2016, 03:42 PM
Caper50's Avatar
Ah yeah, rub it in. It's blowing a gale here, COLD, SNOWING and a wind chill of 7F! BUT 70F in my garage
Btw, tail light panel looks great
Caper50 is offline
post #26 of 156 (permalink) Old 03-05-2016, 05:27 PM Thread Starter
Caper did I mention its 64*, oh nevermind...
Decided to work on the passenger side floor pan. Got it shaped up fairly good. I did have to bend the lip upwards on the short pan (I think they make the lip bent down on all of the short pans so you can use them on convertibles and coupe/fastbacks). I will cut the piece off up at the firewall so that it will be like the factory pan. I do have to weld some on the firewall where the pans overlap each other, so need to get that cut out next.
post #27 of 156 (permalink) Old 03-06-2016, 01:44 PM Thread Starter
Another beautiful day in South Alabama!!
Fitting in the firewall piece that the short pan will weld over and to.
post #28 of 156 (permalink) Old 03-06-2016, 01:46 PM
Titus_RacerX's Avatar
Originally Posted by 66GTCoupe View Post
right on, nothing better than a '66 GT Coupe! I could be biased… Looking forward to the progress
Not gonna argue, but a GT Fastback can't be beat!
Titus_RacerX
'66 GT Fastback, Springtime Yellow. Plant: Metuchen , NJ DSO: Atlanta. AT, A/C. 6T09A111858
Parked since 1980. Carport find that I've been watching for 10+ years.
2013 Nissan Leaf SV
2006 Nissan Pathfinder SL
Code Name: Daisy Photobucket
Often the path to forgiveness is to realize that the other person is an imbecile.
Titus_RacerX is offline
post #29 of 156 (permalink) Old 03-06-2016, 05:35 PM Thread Starter
Another productive day.
Got the firewall piece fitted and welded into place. The short pan still has a good fit to it after the welding. I will drill holes for the spot welds before securing it in place. Not sure if I'll get to do any work this week so it may be next weekend before anything else moves forward...
Allen
post #30 of 156 (permalink) Old 03-20-2016, 06:30 PM Thread Starter
Posted this on main forum, but wanted to put it here as well. I now have the build sheet (it was in the ash tray).
Allen
