Lenny B's 1968 J-Code Coupe Restoration Project - Vintage Mustang Forums
 3Likes
post #1 of 20 (permalink) Old 09-03-2016, 09:04 PM Thread Starter
lennyB's Avatar
Hello Everyone,
I decided to post my current project and will update along the way. Hopefully I can ask for advice to get different Ideas on How To's when I get stumped. The car is a North Carolina car that is pretty much all original except for basic mechanical repairs and a repaint previous owners did along the way. It is a 302 4V, C4 Automatic, with 3:00 to 1 rear axle. The interior is Ivy Gold and the Exterior is Seafoam Green. The only rust issues I've found so far are on both doors. Each door has a dime sized hole the was mudded over at some point near the bottom front of the door skin. Also there is two dime sized holes under the backlite (rear windshield) at the lower corners. Other that that, the body all original metal and super clean. The engine, trans and rear end are in very good mechanical condition. I plan to rebuild all anyway since I don't really know whats inside and I'd like to step up the performance a bit. The following pics are what I'm starting with.
Caper50 likes this.
lennyB is offline
post #2 of 20 (permalink) Old 09-03-2016, 09:38 PM
MikeG69's Avatar
Lenny, nice looking Mustang.
2000 Ranger 4X4 (my DD)
1999 Explorer Sport (wife's DD)
2008 Escape (spare)
1969 Mustang Coupe (project)
Build thread; http://www.newyorkmustangs.com/forum...cs-t15096.html
AKA; mike65
MikeG69 is offline
post #3 of 20 (permalink) Old 09-04-2016, 09:06 AM Thread Starter
lennyB's Avatar
Thanks Mike
lennyB is offline
post #4 of 20 (permalink) Old 09-06-2016, 07:38 PM Thread Starter
lennyB's Avatar
Up Date 9/06/16
Well it took a total of 63 hours to photograph, document, and remove everything from the body. The next step is to strip the entire body and get it into epoxy primer.
9/07/16
Today I degreased the entire body. I first scrapped as much off as I could and then soaked the engine bay and under body with Gunk Engine degreaser. After it soaked for about 20 minutes I scrapped and scrubbed again followed by hosing it off. Then I let the 90 degree heat and sun dry it. Then it used some wax and grease remover and a rag to get the stubborn stuff. After 4 hours of cleaning I would say it's pretty clean. The only real rust I found was inside the front passenger frame rail. Not sure what I'm going to do with that yet. The drivers side is spotless but the passengers side is pitted on the inside.
lennyB is offline
post #5 of 20 (permalink) Old 09-06-2016, 09:53 PM
69GT350H's Avatar
Not bad at all, took me a lot longer to get that done. Wish I had more photos.
1969 Shelby GT350 Hertz rebuild Gallery
Delivered to Ball Ford in Miami Florida, purchased by Hertz Rent A Car for delivery to Miami Internation Airport
69GT350H is offline
post #6 of 20 (permalink) Old 09-20-2016, 07:39 PM Thread Starter
lennyB's Avatar
Hello everyone,
Well, today was my first day of actually being able to work on the body. There are 5 rusted areas I've identified that need cut out. Today I addressed the driver's fender. It had some small bubbles in the paint so I new it was most likely rust under it. After buzzing it down with a stripping disc, my theory was confirmed. I decided to cut out the bad area and then Mig weld a patch in. Besides the Bondo Worms on the inside from a previous owners half hearted repair, I found a bit of pitted rust on the inner support also. I decided to sand blast the inner support and then used Eastwood's Rust Encapsulator on it. I partially spot welded the patch in today and tomorrow I will finish welding it in and then try to get the welds filed down. This is my first attempt at this, so your advice is more than welcome if you know a better way to address this repair (since I have two similar issues, one on each door). I think this is the right way to fix it, what do you guys/gals think?
Repair Photos:
Huntingky likes this.
lennyB is offline
post #7 of 20 (permalink) Old 09-20-2016, 08:24 PM
69GT350H's Avatar
Looks good to me. Better than my first attempt anyway.
69GT350H is offline
post #8 of 20 (permalink) Old 10-07-2016, 04:36 PM
that is a great solid car to build from. i wish i had the benefit of tearing my project down, p.o did the work and lost interest.
warthogdriver77 is offline
post #9 of 20 (permalink) Old 03-01-2017, 08:46 AM Thread Starter
lennyB's Avatar
Well I got the entire shell completely stripped and in Epoxy Primer. Fortunately, there was no rust (other than minor surface rust) or dents and the sheet metal is all original. Next I'll move on the the doors, fenders, and lids.
lennyB is offline
post #10 of 20 (permalink) Old 03-01-2017, 08:47 AM Thread Starter
lennyB's Avatar
After Epoxy. I had to do the car in sections do to the amount of time available to work on it.
lennyB is offline
post #11 of 20 (permalink) Old 03-01-2017, 09:25 AM
Caper50's Avatar
Missed this project when you initially posted, that is a clean car. You are doing a fantastic job.
lennyB likes this.
Caper50 is offline
post #12 of 20 (permalink) Old 03-01-2017, 11:17 AM
Mr.E's Avatar
Are you going back to the seafoam or picking a new color?
1968 Mustang Coupe - work in progress
1965 Ford F100 flareside pickup - daily driver
Mr.E is offline
post #13 of 20 (permalink) Old 03-01-2017, 11:28 AM Thread Starter
lennyB's Avatar
I picked up a pint of "Seafoam" to shoot on a test panel. If I like the way it looks on the test panel, I'll keep it Seafoam. If I can't get the Seafoam color just right, I'll change it to Dark Highland Green. I'm hoping to keep it the original seafoam, and then find another car that is not numbers matching to make whatever I want.
lennyB is offline
post #14 of 20 (permalink) Old 03-01-2017, 11:29 AM Thread Starter
lennyB's Avatar
Thanks Sir
lennyB is offline
post #15 of 20 (permalink) Old 03-01-2017, 01:40 PM
Caper50's Avatar
I think Seafoam green looks fantastic on that body style.
Caper50 is offline
