1970 Door Window Parts Needed - Vintage Mustang Forums
Go Back   Vintage Mustang Forums > Mustang Want Ads > Classic Mustang Wanted Ads
Old 03-06-2006, 09:14 AM   #1 (permalink)
SAH62's Avatar
I need a few parts used to mount 1970 bolt-in door glass:
1 door window upper front stop inner bracket. I could also use two rubber stops in "like new" condition if at all possible.
2 door window guide assembly brackets with D0 casting numbers. The long "run and bracket assembly" bars run through these guides.
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Calypso Coral 428 CJ Mach 1 Mustang
1995 Chevrolet Impala SS
2006 Dodge Charger SRT8
SAH62 is offline   Reply With Quote
Old 03-07-2006, 07:50 AM   #2 (permalink)
SAH62's Avatar
UPDATE: I managed to find a nice set of front stop brackets and bumpers. I also found that I don't have the two rear stop brackets and associated mounting hardware. These should be the same for either '69 or '70. Can anyone help?
I'm still looking for a pair of "C"-shaped 1970 (D0 casting numbers) door window guide brackets as noted above. I need a pair with intact mounting bolts.
Scott Hollenbeck
Old 03-10-2006, 03:51 PM   #3 (permalink)
I have a bunch of the C brackets for 70
I also have the track tube they go on
rsanter@aol.com
rsanter is offline   Reply With Quote
