68 A/C drain hose location - Vintage Mustang Forums
post #1 of 8 (permalink) Old 05-17-2017, 01:48 PM Thread Starter
Does anyone have a good picture of the correct drain hole location for a 68? With the evaporator installed the most convenient location would seem to be on the hump in a straight line from the drain,but there is no dimple there. There is a dimple on the floor a couple inches to the right. This would cause the hose to form a slight S shape and place the hose where it could be kicked. I have seen one pic of a 69 that showed the hose in this locational the floor.
Before I drill a hole I would really like to make sure I do it right.
In the pic you can see the two locations circled with a sharpie; the circle on the left is where the hose would go in a straight line from the drain and end up on the hump. The circle on the right is the dimple in the floor.
While you're looking, anyone know what the two holes punched on the top of the hump are for? They are factory holes, but nothing I can think of mounts there. There are not sealed either, so they just add a path for water to get in.
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is offline
post #2 of 8 (permalink) Old 05-18-2017, 10:18 AM
Shoelessjoe75's Avatar
Mine has the hole for the A/C on the hump. No idea what the other hole is for. I do not have one in that location
Shoelessjoe75 is online now
post #3 of 8 (permalink) Old 05-18-2017, 11:17 AM Thread Starter
Interesting, I noticed that firewall pad has a half circle cout out for the spot on the floor, and the assembly manual says there should be a dimple for the hole.
Any chance you can get a pic of yours?
Flade
66 200 coupe Blue
Flade is offline
post #4 of 8 (permalink) Old 05-18-2017, 11:40 AM
I will try and post it when I get home from work.
post #5 of 8 (permalink) Old 05-18-2017, 02:08 PM
Harleydave's Avatar
Mine is a 68 factory AC car.
68 Fastback.
351Windsor, 4sp, 8" 3.40 TracLok
http://forums.vintage-mustang.com/bu...ld-thread.html
Harleydave is offline
post #6 of 8 (permalink) Old 05-18-2017, 02:33 PM
67gta289's Avatar
I've added a few more pictures. The hose part number is C7ZA-19728-C. Note the spring clamp where the hose is attached to the drain nipple. At the floor there is a retainer that fits around a groove in the hose, and a short screw holds it firmly in place on the floor.
I have a Ford NOS hose but it is nothing like the original C7ZA-19728-C as shown in the pictures. The replacement from classic auto air, shown in one of the attached pictures, is very close and just needs to be cut to length.
I have not found a source for the floor retainer. I've got all the dimensions and thought about making some for those that need them.
67 289 GTA Dec 20 1966 San Jose
67gta289 is online now
post #7 of 8 (permalink) Old 05-18-2017, 09:55 PM
Flade
I apologize that the info I gave earlier was totally wrong. The hole on mine is not on the hump. I was a zombie this morning due to some serious storms that came through last night.
Andy
post #8 of 8 (permalink) Old 05-18-2017, 11:05 PM Thread Starter
Thanks everyone, that is exactly the info I needed. It is clearly the spot on the floorboard where the dimple is located. I have a hose and the retaining clip I had been saving for my 66, I am really surprised everyone sells the hoses but no one sells the retainer. I'll have to hunt down one.
Flade
66 200 coupe Blue
Flade is offline
