1966 Top Pump Haress Clips - Vintage Mustang Forums
post #1 of 2 (permalink) Old 05-19-2017, 10:52 AM Thread Starter
My 1966 Convertible has the top pump motor harness running down the driver side. I know there is some variation with Passenger side routing but mine is originally driver-side routed so I will stick with that. The Electrical Assembly Manual calls for 4 clips C3SB-14A163-B to be used to secure the harness rear of the grommet in the Quarter pier. I understand these are no longer available but would be happy if someone knew where I might get some. Alternatively, is there an acceptable alternative like the 372047 used for the Taillight Harness or "S" clips used elsewhere in the Electrical System?
paulkwilde is offline
post #2 of 2 (permalink) Old 05-22-2017, 12:26 PM Thread Starter
As a follow up note, I found one correct clip from my tear down process prior to restoration, I have attached a photo of the clip. It is similar to the clip used for the windshield wiper hoses cowl connection. However the power top clips are wider and more robust with a metal core for strength.
If anyone has some of the lying around, please let me know.
Thanks,
Paul
