1967 390 Engine? - Vintage Mustang Forums
post #1 of 10 (permalink) Old 02-07-2007, 03:30 PM Thread Starter
Block 32DIF 8F29
Heads:C7AE-A
Intake:C6AE 9425-H
Rear End-79808930/OC-V1
Front Damper-C8AE-6312-B
Transmission-RUGM2-Metal Tag matches Vin # 7T02S
Any help would be great
logan183 is offline
post #2 of 10 (permalink) Old 02-07-2007, 03:38 PM
Send a message via AIM to JDM4401
I am not sure what your asking, but I will guess.
I believe the block date code is 8=1968,F=June,29=day of the month.
The dampner also I believe is for a 68. I am guessing someone change the bottom end over the years with a 68 block. I think the heads and intake are correct for 67.
I know someone will correct me if I am wrong. Hope you findout what you need to know.
JDM4401 is offline
post #3 of 10 (permalink) Old 02-07-2007, 10:07 PM
sixtysevenGTconv's Avatar
trans, I believe RUG-M & M1 is for '67, M2 is '68, M3 is '69.
Crank pulley 6321-B is '68 390GT 1 belt standard application
Intake C6AE-9425-H '66-67 428 PI Aluminum dual plane intake. Believe the correct should be either C7AE-9425-E '66/67 390GT cast iron used from 11/1/66 - 9/17/67 or C7AE-9425-J 390GT cast iron from 9/17/67.
This info is from my casting guide book. I use as a guide ONLY, may not always be 100% correct.
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <myhawk@gsinet.net>
sixtysevenGTconv is offline
post #4 of 10 (permalink) Old 02-07-2007, 10:56 PM
Block 32DIF 8F29 = Block cast June 29, 1968 (likely used in a late 68 or early 69 Ford)
Heads:C7AE-A = 390GT head used during 67-68 on Mustangs and other Fords
Intake:C6AE 9425-H = not the original intake for the 67
Rear End-79808930/OC-V1 = Not sure where these came from. Originally there would have been a tag on the front of the housing under one of the third member retaining nuts
Odd, but two possibilities IMHO. If the VIN is a very late one then its possible this is just an example of a early (normally a 68 trans) application of this transmission model.
Other possibility is that its a 68 trans that someone stamped the VIN on
Isn't turning out to be a "matching numbers" car
Jeff Speegle
Come see us @ ConcoursMustang.com
MCA Shelby Judge, SAAC & Team Shelby Judge (in no particular order
Jeff_Speegle is offline
post #5 of 10 (permalink) Old 02-08-2007, 06:59 AM
What seems odd to me is I don't recall seeing a VIN stamped on the identifier tag. The #'s on those are typically internal plant #s from assembly. I would expect VIN to be stamped on upper ear or rear of main case.
[color:blue]MCA Gold card judge 67-68 Shelby
Certified judge 65-70 Shelby, 67-68 Mustang[/color]
tlea is offline
post #6 of 10 (permalink) Old 02-08-2007, 05:47 PM
dalorzof's Avatar
Would seem way too hard for Ford to organize the trans plant to pre-stamp VIN's on the toploader tags. Would be a nightmare to match up at the assembly plant.
My 68 looks pretty darn original and they do not match.... other than type (RUG AD) but the partial VIN is stamped on the trans mounting flange.
- Douglas Adams
8R03S : 76A I 2A 15M 72 5 U
8R01S : 65A B 2A 28M 72 7 5 - Factory GT
8R01C : 65A M 2A 01E 72 2 W - CS/GT
8F01X : 65A I 2G 20E 24 1 U - EXP500 repli-bute
dalorzof is offline
post #7 of 10 (permalink) Old 02-08-2007, 07:04 PM
Thanks. I read too much into the response. I read it that he had compared the tag and it "matched" what he thought should match a car with a 7T02S car
Jeff Speegle
post #8 of 10 (permalink) Old 02-08-2007, 09:10 PM Thread Starter
I will try to post some pics in the upcoming days
because today I found more confusing info
logan183 is offline
post #9 of 10 (permalink) Old 02-11-2007, 09:01 PM Thread Starter
HOW do you load up pics on this site
logan183 is offline
post #10 of 10 (permalink) Old 02-11-2007, 09:37 PM
Midlife's Avatar
Here's a tutorial...
http://forums.vintage-mustang.com/sh...p?tid/1431524/
'Electrical Guru: Let me Check Your Shorts! Ooops...that didn't turn out right.
http://midlife66.com/harnesses
http://midlifeharness.com
Midlife is offline
