68 fuel gauge - Vintage Mustang Forums
post #1 of 4 (permalink) Old 01-27-2009, 10:56 AM Thread Starter
MikeInVegas's Avatar
68 fuel gauge
Hi everyone,
On my 68, when the tank is full, the gauge only reads half full.
I have a new sending unit at the tank. I don't see any new fuel/ampere combo gauges available for purchase with the usual suppliers.
Any suggestions?
Mike In Vegas
MikeInVegas is offline
post #2 of 4 (permalink) Old 01-27-2009, 11:12 AM
remove the wire at the sending unit and ground it. if the guage reads full the sender is at fault. the arm on the float or the limiting tabs can be adjusted to correct the error.
aka carlite65
C7ZZ-F is offline
post #3 of 4 (permalink) Old 01-27-2009, 11:46 AM Thread Starter
Thanks!
I'll let you know how it goes.
MIV
post #4 of 4 (permalink) Old 01-27-2009, 07:35 PM
10w30dna's Avatar
Don't leave it grounded very long!You can do some damage to those gauges by directly grounding that circuit. If I remember correctly, 22 ohms should put it @ full, and 72 ohms @ empty. I have had the gypo sending units read all over the place.My '69 reads backwards Find a buddy with an ohmeter and check the sending unit at both full and empty. Good luck.
Check out my distributor restoration site! http://428cobrajetcars.com [color:red][/color] Ask about forum member discount!
10w30dna is offline
