'68 J-Code motor - Vintage Mustang Forums
post #1 of 7 (permalink) Old 03-07-2009, 12:00 PM Thread Starter
'68 J-Code motor
Here is a picture of a '68 J-Code motor a friend (My427stang) of mine and I built. Now comes the fun stuff...DETAILING. I plan to detail the motor to MCA Concours driven class. I hope to have the motor painted in the next week, although I have to clean up the air cleaner assembly. This motor was all original and never opened up. Only service parts had been replaced.
68 390 GT Fastback, 68 302 GT Conv,
68.5 428CJ GT Coupe
dtruitt is offline
post #2 of 7 (permalink) Old 03-07-2009, 04:02 PM
Re: '68 J-Code motor
I hope that as you do this engine you will share images and information of your work. Many here will be interested!
murf
jjmurphy is offline
post #3 of 7 (permalink) Old 03-07-2009, 05:06 PM
[quote=6t8-390gt]Here is a picture of a '68 J-Code motor a friend (My427stang) of mine and I built. Now comes the fun stuff...DETAILING. I plan to detail the motor to MCA Concours driven class. I hope to have the motor painted in the next week, although I have to clean up the air cleaner assembly. This motor was all original and never opened up. Only service parts had been replaced.
Your sig indicates you are a '68 fan. The one thing I'd like different on my '68
is a J code. Bad legs and back don't allow 4 speed, as an engineer I like small block.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is offline
post #4 of 7 (permalink) Old 03-07-2009, 06:12 PM
Danny - automatic or stick engine?
Jeff Speegle
Come see us @ ConcoursMustang.com
MCA Shelby Judge, SAAC & Team Shelby Judge (in no particular order
Jeff_Speegle is offline
post #5 of 7 (permalink) Old 03-07-2009, 10:53 PM Thread Starter
'68 J-Code motor
This is an automatic car/ motor. I actually bought the engine/ trans. combo; but for now just the engine is going into the car.
The engine was removed from a Dearborn car and is being installed in a San Jose car. I figured alot of the details should be the same since all J-codes engines were assembled in the same plant (Cleveland). I also took quite a few pictures b/f disassembly which should help.
I have never detailed a small block; so I am trying to get everything right (or as close as possible).
Danny
68.5 428CJ GT Coupe
dtruitt is offline
post #6 of 7 (permalink) Old 03-07-2009, 11:00 PM Thread Starter
I do plan on sharing. I removed the choke stove from the exhaust manifold today; and if all goes well I plan on using the Eastwood manifold paint for them b/f I paint the engine.
Does anyone know if the exhaust manifolds had engine paint overspray like the 390/ 428 did? Also was the thermostat bypass hose installed b/f paint?
Danny
68.5 428CJ GT Coupe
dtruitt is offline
post #7 of 7 (permalink) Old 03-07-2009, 11:35 PM
Yes - I choose to apply a coat of bare metal rattle can lightly to the surface of the block and head below where the exhaust manifolds attach before attaching them to protect the surface from rust - where the engine color would later not reach because of the exhaust manifold.
Remember to have the exhaust manifolds surfaced so you don't have to use manifold gaskets. And start hunting for cork gaskets that have "ears" that line up with all the cut outs, or you will be gluing them on in the correct locations
Will have to check how many and which valve cover bolts were in place at the time the engine was painted and if/which ones were not. IF they followed the same practice used on the early SB engines
Yes by pass and clamps
You may choose to paint the end (where the hose will attach) of the water pump since there would have been a mask slipped over the end of it and one on the end of the thermostat housing since they did not want paint between the hose connection.
Jeff Speegle
