1965 - conflicting engine paint info - Vintage Mustang Forums
post #1 of 17 (permalink) Old 10-20-2010, 06:22 PM Thread Starter
ATaylor's Avatar
I've got a late-65 car with a six cylinder. Which scheme should I paint to? I've got conflicting information.
The table is from Mustang Monthly, the texted page was posted here a while back by a forum member in a thread I've long since lost.
I've painted the engine blue but it's no problem to repaint as I've still got it stripped and on the stand. Personally I like red/black better but I'm trying to go back to stock as closely as possible (but not concours)
(See attached)
ATaylor is offline
post #2 of 17 (permalink) Old 10-20-2010, 08:16 PM
red/black. don't believe everything you see in magazines. the blue pic is trimmed out like a '66.
aka carlite65
C7ZZ-F is offline
post #3 of 17 (permalink) Old 10-20-2010, 09:00 PM Thread Starter
ATaylor's Avatar
Just to clarify, the first thumbnail is from a forum member, the second from MM.
The pics are both from MM, the red/black a 65, the blue a 66.
So if I understand you correctly, there were no blue sixes in 1965?
ATaylor is offline
post #4 of 17 (permalink) Old 10-20-2010, 09:03 PM
no blue blocks in 65.
aka carlite65
C7ZZ-F is offline
post #5 of 17 (permalink) Old 10-21-2010, 04:35 PM
22GT's Avatar
Definately black engine with red valve cover and air cleaner on a 65 200.
It's amazing the mistakes you see in magazines written by "experts".
Here's another jewel from MM:
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #6 of 17 (permalink) Old 10-21-2010, 04:59 PM
schweitzga's Avatar
Send a message via AIM to schweitzga
Wink
Be careful too about putting the decal on the oil breather/fill cap. My original 200 in a January 1965 Dearborn car had no decal on the cap like the one shown in the photo. Lot's of folks seem to be adding all kinds of "original" decals when maybe they really shouldn't.
It's all there, really...
MCA #00181
schweitzga is offline
post #7 of 17 (permalink) Old 10-21-2010, 05:55 PM
22GT's Avatar
Nobody spotted the detailing gaffe on the 289?
22GT is offline
post #8 of 17 (permalink) Old 10-21-2010, 08:25 PM
I see several, depending on what type of 289 it is supposed to be. No cluch on fan, hipo manifolds dont jibe with the vac advance. If it's a K engine, there should be no shield on the side of the carb or the auto choke or A/C system. Looks like an accessoried-up A code as it stands.
1967 Shelby GT350 4-spd #3014 Concours Gold MCA and SAAC
1965 K code Fastback owned since 1977- MCA Concours Gold
1966 6-cyl. A/T Sprint Convertible owned since 1978
1966 C-code A/T Convertible restored 2008. Exercised regularly in season!
1965 C-code A/T Convertible resto completed May 2015
*New project* 66 a-code 4-spd GT CV barn find-parked since 1976
All owner-restored in my garage, never trailered.
MCA #2254 1964 1/2-66 Concours Judge
ajd350 is offline
post #9 of 17 (permalink) Old 10-21-2010, 08:31 PM
drummingrocks's Avatar
The Cobra wrinkle-painted valve covers on an otherwise Hi-Po cloned motor?
Edit: How about the plug wire routing?
drummingrocks is offline
post #10 of 17 (permalink) Old 10-21-2010, 10:29 PM
22GT's Avatar
Actually, Ford used that fan with and without a clutch.
HP manifolds were a Ford OTC upgrade into the 1980's.
As were the painted Cobra valve covers, which are still available.
The C5ZZ-W air cleaner was also a popular upgrade.
Basically, AJD is right, it's an "accessoried-up A code" engine. In a magazine article.
With the fan on backwards.
22GT is offline
post #11 of 17 (permalink) Old 10-22-2010, 07:49 AM
Oh, that's good! Nice attention to detail on their part. Good example there, 22.
ajd350 is offline
post #12 of 17 (permalink) Old 10-22-2010, 09:58 AM Thread Starter
ATaylor's Avatar
I had a little trouble finding the correct colors, but I'm going with red & black.
I'm still wondering about those late-65 engines as I ran across a concours Falcon site and they were reporting some blue sixes at the end of the '65 run.
As I don't have a concours build and I like the red/black better it was an easy decision for me. For a daily driver a black block seems so much more practical than a lighter color. I guess I'll find out!
ATaylor is offline
post #13 of 17 (permalink) Old 10-22-2010, 10:50 AM
yelostang's Avatar
Maybe a few were blue, at the end of 65 run. But, seems best to stay on the accepted side and go black.
yelostang is offline
post #14 of 17 (permalink) Old 01-01-2017, 12:02 PM
bpugh1975's Avatar
I know this post is ancient, but just now finding time after having 3 daughters to start checking out the forums again
I have a 1965 Fastback 200 ci from the San Jose plant and am not sure if I have the original engine or not (I purchased the car from a guy who purchased it from the original owner and he didn't end up messing with anything before he found another project), but my block was blue, had a casting number of C5DE 6015-H and a build date of December 22, 1964. My engine tag was black, so that got me to thinking the block may have been replaced at some point with one that was blue. I've since painted it black with the red valve covers and air cleaner, but was always VERY curious if the car originally came with a blue motor.
'65 2+2 - 200 3 spd
bpugh1975 is offline
post #15 of 17 (permalink) Old 01-01-2017, 01:06 PM
69mach351W's Avatar
No, did not come with a blue motor in 65. All blocks in 64.5-65 are black.
1965 200ci has "either" blue valve cover OR orange-red valve cover.
This info comes straight from the MCA 64.5-65 rules; section G; Engine components to be painted.
From your engine casting # your block is a Falcon block denoted by the first "D". And the "H" is a high revision #. The 6th revision. Probably a service block for Falcon.
1969 Mach 1, MCA Conservator #256
MCA 69-70 Gold Card Judge
69mach351W is offline
