64.5 Power Steering Pumps - Vintage Mustang Forums
post #1 of 6 (permalink) Old 11-15-2010, 10:36 PM Thread Starter
john_simms's Avatar
Hello all,
I'm a newbie to this forum; so if this question has been asked before, please forgive me.
A little background...
I have an early 64.5 (April 15, 1964 DOB) that I've owned for 30 years. My kids are pretty much out of the house now leaving me with more time and money to do what I want for a change. I started doing research on my car and discovered that it was originally equipped with power steering. Sometime before I bought the car, the complete power steering system was removed, except for the cylinder mount bracket on the frame rail. I had always wondered what that bracket was for and when I decoded the steering box tag, I found out.
From what I've been able to piece together from articles and pictures on the Internet, I assume it should be equipped with an Eaton pump with an integral tank since I do NOT have A/C. I also know that I will need hoses, brackets, the proper drag link, tie rod ends, control valve, cylinder, bolts, nuts, etc.
I have seen pictures of both cast iron and stamped steel pump brackets for this car, but I am unsure which one is correct for my build date. I'm assuming cast iron, but not totally for sure. I'm hoping someone might have a detailed picture or two of what this setup should look like.
I'm hoping there are a few knowledgeable people out there who can provide some assistance and correct my assumptions. Any help or guidance would be much appreciated.
Any recommendations as to where obtain a "complete" PS system?
As I stated before, I've owned and driven the car for 30 years without the PS, so if the correct answer is to leave it as is and forget the PS, that's fine too.
Thanks in advance for the help and opinions.
John Simms
Edwardsville, IL
Car details:
64.5 Coup
289 cid
4V Autolite Carb.
4 Speed Man. Trans.
Power Brakes
2 Speed Wipers
Rocker Moldings
john_simms is offline
post #2 of 6 (permalink) Old 11-16-2010, 01:25 AM
I have a mid-April D-coder that still has all the original PS stuff. It's a driver so not pretty but I can shoot a few pix of the brackets and pump. I rebuilt the Eaton pump after buying the car 20 years ago and was pretty impressed with its simplicity and condition. It took a standard 3/4" hydraulic shaft seal that I use on hydraulic pumps in the shop and a couple of o-rings and a gasket to mount the tank. I imagine the under-car gear is similar to a 65. I've had zero trouble with the system since I've owned the car and it sat for eight years until just recently. You should be able to rob some parts off of other Ford cars of that era.
I'll try to get something up tomorrow. In the meantime, here's a web image of the exact bracket which is on my car.
http://forums.vintage-mustang.com/signaturepics/xsigpic18756_2.gif.pagespeed.ic.3vzsIY6Mah.jpg
Visit my VMF lingo page
Visit the Ford engine torque specs page
Visit my MySpace Blog
camachinist is offline
post #3 of 6 (permalink) Old 11-16-2010, 07:39 AM
CHOCK's Avatar
Originally Posted by john_simms View Post
Hello all,
John Simms
Edwardsville, IL
Car details:
64.5 Coup
289 cid
4V Autolite Carb.
4 Speed Man. Trans.
Power Brakes
2 Speed Wipers
Rocker Moldings
Give me a call John, We have what you need, Factory correct.
South of Jacksonville, Ill, just a few minutes away.
Dan @ Chockostang
217 882 2083
CHOCK is offline
post #4 of 6 (permalink) Old 11-18-2010, 11:47 PM
65fastback6's Avatar
You may want to check out this website:
www.stangerssite.com
a lot of great info on the power steering system.
I have the used original power steering parts that you need,
leave me a PM if interested.
65 Fastback 2+2 Rangoon red, red interior
6 cyl, AT, A/C, P.S., P.B.
MCA# 00945
Previously owned Mustangs:
6F07C,5F07T,5F09A,6F08A,
5F07C,3F03F,1F03H,3F03H,
1F04F,3F01L,8F03Y,9F03W,
84 SVO,86 SVO
65fastback6 is offline
post #5 of 6 (permalink) Old 11-19-2010, 04:37 AM
bryancobb's Avatar
Here's a suggestion that will reward you for many moons! Get Bob Mannel's book on the Small-Block Ford engine in the Mustang. I cannot describe how much very accurate, detailed information is provided in this 500 page book on questions just like you are asking.
www.fordsmallblock.com
bryancobb is offline
post #6 of 6 (permalink) Old 11-19-2010, 07:41 AM Thread Starter
john_simms's Avatar
Thanks. Ordered a copy this morning. I love Christmas presents to myself!
