Hurst T5 shifter NEW
Brand new shifter in box .
Asking $165 shipped .... ebay is $195
Will post pics
Hurst Ford-Mercury Billet Plus Shifter
Application:
'94-'01 Ford MUSTANG, V6/V8 465 BW T-5 & T-45 Trans
'83-'91 Ford THUNDERBIRD, V6/V8 465 BW T-5 Trans
'83-'91 Mercury COUGAR, V6/V8 465 BW T-5 Trans
Hurst Billet/Plus Shifters incorporate a high ratio pivot mechanism for reduced shifter throw and are sturdily constructed for a more positive precise feel when shifting. Self centering alignment improves 2nd to 3rd up-shift gear changes to reduce the chance of “missed shifts”. Patented adjustable bias spring loads on most models allow stick tension to be tailored to drivers preference. Dedicated applications assure a custom fit and eliminate any vehicle modifications for ease of installation.
All Mustang Billet/Plus shifters are supplied with black steel stick that is threaded to accept stock factory knob. Shifter knob not included
Features & Benefits:
• CNC machined 6061 T-6 BILLET ALUMINUM base and stop collar
• Heat treated BILLET STEEL gear selector for ultimate strength
• High strength steel stick. NOT A CASTING!
• Adjustable positive gear stops to help prevent internal transmission damage
• Stainless steel rotating pivot insures smooth shifting and reduced wear
• Polymide pivot cup reduces stick vibration and noise transfer
• Self centering alignment for improved 2nd to 3rd upshift gear changes
• Patented adjustable bias spring load for ease of operation
• Exclusive oil control seal, on most models, to eliminate trans fluid loss and protect against contamination.
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
