9" posi, 3:50, 31 spline - Page 3 - Vintage Mustang Forums
post #31 of 44 (permalink) Old 01-09-2016, 11:51 AM Thread Starter
Posi
This is a 1974 N Case, 31 spline, 4 pin, 3:50 geared posi / limited slip. This is a used drop out.The gears will work, but they are rust pitted. No cracks or chips in teeth, front pinion seal was dry when removed from F100/150. Can send pics of gear teeth via email if you like. Run as is if you like. I need $600 for this unit, plus shipping USA. Because shipping is so expensive, (Jan 1st they increased rates), I will cover anything over $100 in MOST cases. Thanks.
New price...$600 plus shipping.
MYTANG is offline
post #32 of 44 (permalink) Old 01-12-2016, 09:36 PM Thread Starter
Here's an all new 31 spline posi unit, with new 3:50 gear ratio gears, 10 used posi bolts with washers, and a used 3L50 limited slip id tag. The bearings were put on the new unit were very low miles in excellent shape. Great stuff to put in your 9 center section, and your yoke would be correct. $400 plus shipping USA.
MYTANG is offline
post #33 of 44 (permalink) Old 02-05-2016, 08:32 PM Thread Starter
Originally Posted by MYTANG View Post
This is a 1974 N Case, 31 spline, 4 pin, 3:50 geared posi / limited slip. This is a used drop out.The gears will work, but they are rust pitted. No cracks or chips in teeth, front pinion seal was dry when removed from F100/150. Can send pics of gear teeth via email if you like. Run as is if you like. I need $575 for this unit, plus shipping USA. Because shipping is so expensive, (Jan 1st they increased rates), I will cover anything over $100 in MOST cases. Thanks.
New price...$575 plus shipping.
ttt...lowered again.
MYTANG is offline
post #34 of 44 (permalink) Old 02-13-2016, 08:43 PM Thread Starter
Now $380 plus USA shipping. Thanks.
MYTANG is offline
post #35 of 44 (permalink) Old 02-14-2016, 04:09 PM
Today I have a older Equal Lock for sale. If your car had an equal lock originally, you need this! It was all apart in a box when I got it, I'm not to sure if its missing anything. If anything it looks like there are extra parts. I do have a pic of the inside parts to send via email. YES YOU CAN GET PARTS for these equal locks, I can send links to sellers, and info I have collected. I only want $100 + shipping in U.S. Thanks...
can you send me pictures of what you have on this unit? thanks jacryoung@gmail.com
Jerry 10 is offline
post #36 of 44 (permalink) Old 02-28-2016, 09:13 PM Thread Starter
Now $375 plus USA shipping. Thanks.
ttt
MYTANG is offline
post #37 of 44 (permalink) Old 03-24-2016, 11:26 PM Thread Starter
ttt
Down to $350 plus us shipping.
MYTANG is offline
post #38 of 44 (permalink) Old 04-10-2016, 09:40 AM Thread Starter
These items are still for sale MINUS the bolts...I needed them. I would sell gears separate from the posi unit if wanted, and the tag would go with the gears. The bundle is now $325 plus shipping.
MYTANG is offline
post #39 of 44 (permalink) Old 07-31-2016, 09:14 PM Thread Starter
More 2 sell
Hi peoples...I'm back. I have decided to sell the next two 9"posi units I have AS IS, meaning I will still inspect them carefully, give all the details I can see honestly, all without cleaning them up and painting them. Cleaning and painting is very time consuming for me, and my back limits me greatly on how many times I can handle these heavy buggers.
This unit here is a 31 spline, heavy duty 4 pin posi, with 3:50 gears. Some rust stained teeth, that will not effect the operation of the unit. I will send teeth pics if wanted via email. It will need a front pinion seal OR a sleeve for the yoke. Both are easy to do, and both are a $10 part each. I package these units safely, take time off work, and deliver to a carrier...(60 mile round trip), an extra charge because the unit is sent special handling because of weight, so I really cant cut a break on shipping, which in total cost me on average...$100. I need $400 for this unit.....FREE SHIPPING up to $100 Anything over that, will be applied to the total price. PayPal or Postal Money Order works the best for me.
The second unit below had a broken rib on the case that looked terrible, so I swapped the case out to a good extra one that I had. That means the backlash on the gears needs to be reset, and side load on the bearing caps before using. Its the exact same condition as the first unit described. I need $380 for this one, same shipping and payment as previously described. Thanks for looking.
MYTANG is offline
post #40 of 44 (permalink) Old 08-01-2016, 02:22 PM
OldMil's Avatar
Sorry to start this, but the 2nd unit on the grill....is that a"chunk roast"?
1970 428CJ Mach-1
MCA# 60075
"Every day's a Holiday, and every meal's a Picnic"
jackm@parkcitycu.org
OldMil is offline
post #41 of 44 (permalink) Old 08-01-2016, 06:31 PM Thread Starter
Silly Willie...its a hogs head fresh off the grill...get it while its hot
I also have guts in the oven, and a pumpkin in the fridge. Get it?
My wife has a very nice rear, but she's keeping it....sorry.
MYTANG is offline
post #42 of 44 (permalink) Old 10-09-2016, 12:27 AM Thread Starter
The grill posi is now priced at $350 plus shipping...Thanks.
MYTANG is offline
post #43 of 44 (permalink) Old 01-27-2017, 08:12 PM Thread Starter
This is a 1974 N Case, 31 spline, 4 pin, 3:50 geared posi / limited slip. This is a used drop out.The gears will work, but they are rust pitted. No cracks or chips in teeth, front pinion seal was dry when removed from F100/150. Can send pics of gear teeth via email if you like. I need $650 for this unit, plus shipping USA. Because shipping is so expensive, I will cover anything over $100 in most cases. Thanks.
Lowered this unit to $550, same circumstances. Thanks...
MYTANG is offline
post #44 of 44 (permalink) Old 03-11-2017, 10:17 PM Thread Starter
Spring is close...N Case posi lowered to $525, same circumstances. Thanks for looking.
MYTANG is offline
