holley power valve issues - Vintage Mustang Forums
 3Likes
  • 1 Post By maladezo
  • 1 Post By Alan _MacDougall
  • 1 Post By gt350sr
post #1 of 9 (permalink) Old 05-18-2017, 08:34 AM Thread Starter
We have a 66 coupe that we built up and the hypo motor has a holley street avenger carb on it with fuel pressure regulator and gauge. It had been running great but has been sitting for some time as my son has been deployed. Now it backfires upon acceleration blowing the power valve spewing gas all over the engine and it poses a serious fire hazard. I want to get it dialed in for his return in a few weeks. So what is causing this problem and what can I do to fix it?
Voodoo1 is offline
post #2 of 9 (permalink) Old 05-18-2017, 10:31 AM
maladezo's Avatar
Generally, a Holley spews gas when the needle valve is not holding the fuel pressure. The newer Holleys have power valve protection, so I doubt it is blowing. Try dialing down the fuel pressure, and check the power valve to be sure.
TommyK likes this.
'67 coupe, 390-S, 4spd.
maladezo is offline
post #3 of 9 (permalink) Old 05-18-2017, 11:09 AM
Alan _MacDougall's Avatar
Ethanol in the gas eats up the power valve and float needles. Time for a rebuild and switch to pure gas.
gt350sr likes this.
Alan _MacDougall is offline
post #4 of 9 (permalink) Old 05-18-2017, 03:52 PM
This! Happened to my brand new street avenger after only a year. Didn't run it much and paid the price. Rebuild fixed the problem, though mine was just the power valve.
2008 Bullitt|Roush M90 w/ 2.57 pulley and CAI, 90mm MAF, Steeda UCA, LCAs, Hyperco springs, Brenspeed tune, Roush shifter, a few other things|
1969 Coupe Restomod-never complete!
2008 Power Wheels Bullitt Clone
Mustangs from the past: 66 coupe, 69 Coupe, 69 Grande, 2001 Bullitt, 2011 V6
rangerdoc is offline
post #5 of 9 (permalink) Old 05-18-2017, 04:13 PM
gt350sr's Avatar
There's no place for Ethanol in these older cars.... or my lawn mower for that matter! I try to stick with the straight stuff 91 octane when possible.
Alan _MacDougall likes this.
Buckle up- I wanna try something!!
gt350sr is online now
post #6 of 9 (permalink) Old 05-18-2017, 04:53 PM
supershifter2's Avatar
over the years some friends with newer cars that sat for a few months had the in tank fuel pump go bad due to the ethanol in the gas. use an all metal needle and seat in your golley carb
supershifter2 < !
supershifter2 is offline
post #7 of 9 (permalink) Old 05-18-2017, 05:19 PM
maladezo's Avatar
How good are the Street Avenger Holleys? Never tried one. I like that they have dual metering blocks and jetable secondaries.
maladezo is offline
post #8 of 9 (permalink) Old 05-18-2017, 05:44 PM
turbo2256b's Avatar
pERFER THE QUICK FUEL carbs these days more easly adjustable use several of them with no issues. Recomend using the alcohol proofed power valves, accelerator pump diaphragms from QF also.
turbo2256b is offline
post #9 of 9 (permalink) Old 05-18-2017, 06:31 PM
TommyK's Avatar
The only personal experience I have is with the 670 SA on a 4V Cleveland and then on a mild 460. They are generally calibrated a bit on the lean side and they have accelerator pump issues due to return spring interference with the pump lever.
Like anything else they can be made to work.
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.25 trac lock
TommyK is offline
