Dear @all,
I need to replace a leaking axle seal on my '68 9" axle. Oil is leaking into the brake drum. So far as I remember I need to remove the 4 retainer screws that hold the axle retainer and the brake-backing plate to the axle.
Does the backing plate and the brake cylinder need to come off, too?? Or is it posible to remove the seal w/o disconnecting the wheel brake cylinder??
Thank you!!
Make it a great day!
Joachim
