Horsepower TV's Pro-touring Pony 65 fastback/431w, 66 Shelby resto theme/393 paxton, 67 Eleanor 540fe/Procharger F1R, 66 shelby theme {wifes car, 347/paxton}
"People make grand plans for life as it passes them by"
I was thinking about this as I have too many Mustangs to keep the batteries charged.
Bragger
Steven
Hickory, NC
1966 Coupe
Replaced
Full floor pan
Firewall
Full cowl
Radiator support
Up next:
Shelby drop, 4 wheel drum to disc conversion, rebuild front suspension/steering, taillight panel, trunk floor,302 and AOD upgrade, wiring harnesses back in, and hopefully only patch panels on the quarters
E=MChuck Norris
Battery Tender makes solar panels specifically designed to keep batteries charged. They're not cheap. But buying one might be easier than trying to convert a generic solar panel to charge a battery.
Battery Tender also has charging units that will connect to multiple cars. What's nice about their stuff is it has built-in circuitry to keep the batteries charged without overcharging them.
You'd need a 12 volt panel, not 2. Unless that was typo.
Some later model VW's had a option for a solar panel that had suction cups to stick to the windshield and plugged into the cigarette lighter. I don' know what cars they in, if they were a dealer parts counter option or what but a friend gave me one and it works great.
If I were after making one I'd buy one of those cheapo Harbor Freight float chargers and clip off the 110 volt transformer and wire it to the panel(s). I have one of those chargers and it works surprisingly well for $6. They go on sale pretty regularly. Normal price think is more like $10. Between the transformer and the alligator clips is plastic box with an LED that contains the "float" circuit board.
Besides preventing over charging battery tenders actually discharge the battery periodically in addition to recharging them. This is what enables a battery tender to extend the life of batteries by several years.
Not bad. For that kinda money it would be worth the try.
As for the 2v thing, I thought that would be what was needed to "trickle" charge the batt.
Amps. Most trickle chargers charge with 12 volts and 1 ampere. My big charger's low charge mode is 2 amperes. Solar charger I have no clue but I expect it varies with the sunlight.
Crap, your right, I don't know what I was thinking.
Yep, 12 Volts, 2 amps trickle charge.
I have a battery that's over 10 years old on a Tender.
25 years ago I bought a solar charger from JC Whitney. It worked, well enough to keep a car parked weeks at a time. Plugged into the lighter.
Amateur restorer. (Well, once in a while I have been paid for it)
I use a cheapo solar charger on the roof of the trailer--keep it plugged in anytime it sits. Had a similar one for my Dad's airplane. I doubt I paid more than $20 for either one.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
