Rear Disc Brake Kits - $449 - Vintage Mustang Forums
post #1 of 1 (permalink) Old 04-11-2016, 02:20 PM Thread Starter
Supporting Vendor
GPS Automotive's Avatar
Are you ready to add rear disc brakes to your Ford axle without breaking the bank?
The GPS Automotive rear disc brake kits include
  • 63.5mm Zinc Plated Single Piston Calipers with Built-In Parking Brake
  • Precision Machined Caliper Mounting Brackets with Multi-Position Mounting Capabilities
  • All Mounting Brackets are Zinc Plated for a Long Lasting Finish
  • 11.25" Vented Rotors with Ford 5 x 4-1/2" and GM 5 x 4-3/4" Bolt Pattern
  • DOT Rubber flex lines with 3/8-24 SAE female inlet
  • Brake line mounting tabs, spacers & mounting hardware
  • Complete installation instructions walking you thru every step of the installation with pictures.
Check out the links below to choose the correct kit for your axle.
8" & 9" Small Bearing Rear Disc Brake Kit
9" Large Bearing Rear Disc Brake Kit
9" Large Bearing "New Style" Axle Rear Disc Brake Kit
File Type: jpg GPS Automotive Ford 9in Rear Disc Brake Conversion 1200x1550.jpg (93.0 KB, 9 views)
GPS Automotive - Your Classic Mustang Brake System Specialists.
Check out all of our 64.5-73 Mustang Brake Products at GPSBrakes.com
Click Here for basic brake FAQ's in our Tech Center
GPS Automotive is offline
