1966 Mustang brake light switch installation - Vintage Mustang Forums
 2Likes
  • 1 Post By 66/93project
  • 1 Post By 66_5.0
post #1 of 5 (permalink) Old 03-09-2017, 03:55 AM Thread Starter
Hi all,
I'm in the process of trying to put my car back on the road and I have run into the issue of the brake light switch.
I have read many...many threads on this topic however I just seem to not get it.
The issue I am having is the brake light switch fully covers the shaft that comes off of the brake pedal preventing it from being able to be secured with the C clip. It's almost as if the shaft shrunk.
It was on there before...so I know it fits...somehow.
I saw another member having the same issue but I couldn't remember if they got it fixed or went with the GM part.
I would greatly appreciate all input...seeing as how this is 1 of 2 things left to get the car back on the road.
Ulises
66_5.0 is offline
post #2 of 5 (permalink) Old 03-09-2017, 06:34 AM
66/93project's Avatar
You have some bushings or spacers that are not properly lined up I think. Mine goes on quite easily.
awhtx likes this.
66 coupe | deep impact blue | 17" US Mags Ramblers | DSS 331 | TFS heads/Stage 1 cam | Dynomax Bullet mufflers | 3.80 Trac Lok posi | C4/Shift kit | PA Performance Billet Servo/Finned deep pan | CalTrac bars | 120mm Halo led grill lights | iPad mini Console/hidden pioneer stereo | Enclosed trunk/10" Kicker
Finally completed- working on last bugs....
66/93project is offline
post #3 of 5 (permalink) Old 03-09-2017, 08:27 AM
There's a picture of how everything should line up in the shop manual. This shot's from the '67 manual, but '66 is probably close.
Make sure though that you haven't knocked that center piece out of alignment. If it gets crooked it can push the sides out and make it too wide to fit.
Last edited by Magnus; 03-09-2017 at 08:28 AM. Reason: Added that this is from the '67 manual
Magnus is offline
post #4 of 5 (permalink) Old 03-09-2017, 01:22 PM Thread Starter
Thank you for the replies. I have looked at that diagram over and over...still couldn't get it on. Now here's why..
I took a trip down to a local mustang parts store to explain the issue....and I found out I have a 64 1/2 brake pedal.
The 66 has a longer shaft....it's about 2x bigger than the 64 1/2.
Now...a question I have now is has anyone made a 64 1/2 brake pedal work on a 66? Apparently mine did somehow because it was working before I pulled the pedal assembly out.
Btw.... I bought the 66 pedal....and am hoping I don't have to rip the assembly out again.
Ulises
66_5.0 is offline
post #5 of 5 (permalink) Old 03-15-2017, 10:20 PM Thread Starter
Ended up having to replace incorrect pedal with the correct pedal.
Had to disassemble the brake pedal support housing and re-install it a second time.
It took me 15 second to put the brake light switch on with the CORRECT pedal. 😡
Huntingky likes this.
66_5.0 is offline
