aftermarket fuel gauge - Vintage Mustang Forums
post #1 of 6 (permalink) Old 09-30-2007, 01:55 PM Thread Starter
Fordguy65's Avatar
Its a good day to be in the garage...
I am putting in my new dash. I am using an Auto Meter fuel gauge and I am not sure how to hook it up to the stock harness. There is a black wire and a yellow wire going into the back of the stock gauge. The autometer has the usual sender, ground, and 12 v locations. I tried using the yellow as the sender hook up, but I get a very low reading with about 1/2 tank of gas. Suggestions? I know there are a few of you who have already done this...
TIA,
Jim
Jim Smith
Atlanta, GA
1965 Coupe 5.0 GT40 Intake and Heads, 65MM TB, chipped, T5, Shelby drop, roller idler, subframe connectors, Magnaflows, Hurst shifter, MS clutch, BFGs on 15" TTDs, Roller perches, Bilsteins, 3.54 gears, LS, Needs everything else...
"If you didn't build it; it's not really yours."
Fordguy65 is offline
post #2 of 6 (permalink) Old 09-30-2007, 02:42 PM
Tims65's Avatar
Jim,
Did you install a new fuel sender with the gauge? The gauge registers the ohms sent by the fuel sender. The early Ford sender sends 75-10 Ohms (empty-full). Most after market gauges use the Chevy sender, which sends 0-90 (empty-full), which would give you an opposite reading.
Exactly which Autometer gauges did you get?
Tim
'65 2+2
347 - Holley DP - 471 fwhp
JBA shorty's, 2.5" tubes, Dr Gas X-pipe
T-5 world class 5 speed, w/ .80 OD
9" with 3.70's & T-loc
4 wheel Wilwood disc brakes
17" CL-205's, 225/45 & 255/40
TCP/Global West suspension
OpenTracker roller spring perches
subframe connectors, Panhard bar
TCP manual rack & pinion
Power door/window locks w/ keyless entry
Driven, not pampered
Tims65 is offline
post #3 of 6 (permalink) Old 09-30-2007, 05:32 PM Thread Starter
Fordguy65's Avatar
It was the fuel gauge for the 73 emoty and 8 -12 full. It says it is for most Ford and Chrysler vehicles...Should I measure across both wires to get an ohm reading? I think I have about 1/2 a tank...
Thanks for your help,
Jim
Jim Smith
Atlanta, GA
post #4 of 6 (permalink) Old 10-02-2007, 11:25 AM Thread Starter
Fordguy65's Avatar
Got it figured out.
It seems if your tank is empty a correctly functioning fuel gauge will register empty.
Hmmm....
I had assumed I had 1/2 a tank when I was in reality on fumes. Good thing I stopped to fill it up. All gauges are working awesome. I'll post some pics of my new dash later on this week.
Jim Smith
Atlanta, GA
post #5 of 6 (permalink) Old 10-02-2007, 03:04 PM
Glad you figured it out. I recently installed Auto Meter Ultra-Lites in my car (after running with the stock gauges for 3 years.. and running out of gas quite a few times). The driving experience of the car is much better when you are not worrying about if you are going to run out of gas
James
66 Fastback - 302, C4, 8" w/ 3.80 posi, Granada Discs
06 Mustang GT - Satin Silver, 5 spd, JLT Intake, Flowmaster, 3.73, Bassani X-Pipe, UDP - SOLD
2011 GT500 - Black with a few mods.
www.fastbackmustang.com
donovanjamesl is offline
post #6 of 6 (permalink) Old 10-03-2007, 11:04 AM
Send a message via AIM to endlesswishing
Try driving your car halfway across country a week after buying it. I filled up in Nashville, and 3/4 of a tank later, I ran out of gas in the middle of eastern Arkansas. I replaced my gauge cluster when I bought my woodgrain insert, and now empty's empty again.
Why beat around the bush when you can drive a lawnmower right through it?
endlesswishing is offline
