65 radiator with serpentine belt - Vintage Mustang Forums
Old 11-13-2007, 06:24 PM   #1 (permalink)
I was wondering if anyone is using this set-up and if so what do you do for the lower hose when using the reverse rotation pump with RH outlet? For several years I have just used two hoses connected with a pipe but even though nothing shows but the clamps it is not a really clean looking solution. Does any company make a hose for this set-up? I have searched through the stocked hoses in several auto parts stores with no luck so far.
2late is offline   Reply With Quote
Old 11-13-2007, 10:35 PM   #2 (permalink)
Several people here are using a 2.9L BroncoII upper hose trimmed to fit, seems to work very well and look like it belongs.
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
gotstang is offline   Reply With Quote
Old 11-13-2007, 11:46 PM   #3 (permalink)
Thanks I will check that out. I have been under the car quite a bit lately and that darn hose just don't look right.
Old 11-14-2007, 11:33 AM   #4 (permalink)
copasspupil's Avatar
The upper hose from a bronco works. Ron Morris made a lower metal hose but it did not for me at all. You can take the car to a radiator/muffler shop and have some aluminized pipe made to fit. That is what I did.
copasspupil is offline   Reply With Quote
Old 11-14-2007, 01:40 PM   #5 (permalink)
I just noticed a typo in my first post, I said a RH outlet when it actually is a LH. I have two hoses connected in the middle with a stainless steel pipe and all of the pipe is hidden but there is the two clamps showing, does not look that bad maybe I am just being too picky.
Old 11-14-2007, 03:11 PM   #6 (permalink)
I photo would help.
Old 11-14-2007, 03:54 PM   #7 (permalink)
gothand's Avatar
I'm using a Bronco II lower hose with manual transmission for my UPPER hose and a regual '70 lower hose with a few inches trimmed off for my lower hose.
'65 2+2 EFI
gothand is offline   Reply With Quote
