how to install eleanor body kit - Vintage Mustang Forums
Old 12-18-2007, 12:02 AM   #1 (permalink)
ok got my kit at home, and i have noticed it is gonna be a real p.i.t.a.. only type of instructions say side skirts and fender flairs are mold on type, also nothing is pre drilled on the nose section (which is probly a good thing) should i just line it up and drill out the fiber glass to match the old holes?
any advise would be greatly appreciated! !
onegreedy67 is offline   Reply With Quote
Old 12-18-2007, 12:05 AM   #2 (permalink)
White Elephant Guy
obsidianspider's Avatar
Send a message via AIM to obsidianspider Send a message via Yahoo to obsidianspider Send a message via Skype™ to obsidianspider
Step 1: Open garbage can
Step 2: Insert Eleanor body kit
Step 3: Close garbage can
:p
As you can tell, I'm not a fan of E cars. Seriously though, take your time fitting everything. Fiberglass is notorious for needing a lot of work in order for it to fit correctly.
Todd Dietrich - '66 T-Code Fastback, '07 GT/CS Coupe
VMF Facebook Group
obsidianspider is offline   Reply With Quote
Old 12-18-2007, 02:15 AM   #3 (permalink)
I was curious about this as well. Say for the wheel flares.. I don't feel comfortable sticking them on bare metal and painting over, or even just primer, and I sure don't want to paint, install, paint again.. . Whats the 'correct' way for that type of thing?
JohnnyK is offline   Reply With Quote
Old 12-18-2007, 07:22 AM   #4 (permalink)
67 Evil Eleanor's Avatar
Heres a couple of tricks that may help. Test fit the wheel flairs and drill and attach them with 6 or 8 screws. Mark the location with a marker. Remove and trim the fiberglass flairs as necessary. Use freezer paper (wax) and tape it to the surface that you are going to bond to waxy side out. Clean and rough up the inside of the fiberglass flairs to insure a good bond. Fill the inside with ample fiberglass and let it buldge over the lip, be careful as not to get it on the outside of the flair. Quickly attach the flair with the screws. You will see the excess fiberglass ooze out. Let it firm up and remove the screws before it completely cures. Remove the excess fiberglass, you can cut it with a razor if you dont wait too long. Remove the freezer paper. Doing this creates a wide area for your panel bonding adheisive to attach (use one for fiberglass to steel say 3M). Rough up the metal fender lips with 36 DA sander. Clean both surfaces that are to be bonded. Apply the panel bonding adheisive and attach the flair with the screws. Remove the excess. Let completely bond and remove the screws and fill with Fiberglass. Bondo may shrink and leave a outline of the screw hole. You can do this to attach the scoops, rocker panel covers, etc. This makes a perfect fit and will insure a good bond.
"The important thing is not to stop questioning. Curiosity has its on reason for existing"..........Einstein
65 Fastback 66 Vert 67GT500E (re-creation) 68 Notchback Racer 68 Vert 68Gt500KR 71J code Mach One 72 Mach One 73 Mach One
67 Evil Eleanor is offline   Reply With Quote
Old 12-18-2007, 07:27 AM   #5 (permalink)
Mach6903's Avatar
Evil is the Man!!
1969 Mustang Mach 1 428CJ
1988 Mustang LX 5.0 Conv
2002 Ford F150 Harley Davidson
2003 Mustang Mach 1 DOHC
Mach6903 is offline   Reply With Quote
Old 12-18-2007, 08:48 AM   #6 (permalink)
PM sent.
"The danger of communication is the illusion that it has occured"
DaveSanborn is offline   Reply With Quote
Old 12-18-2007, 08:51 PM   #7 (permalink)
Where did you get your kit from? I got mine from Rebel Mustang. Got the hood and front end and the rest will be here this week.
Mustang9668 is offline   Reply With Quote
Old 12-18-2007, 09:45 PM   #8 (permalink)
Gulp... Unique Performance.
The Ecar in my sig pic is not mine. It's a car I built last year and am very glad to be done with it.
Video link #1
Video link #2
Dave
Old 12-19-2007, 12:37 AM   #9 (permalink)
i was told by a body guy today that he would recomend attaching studs to the inside of the skirts and flairs and then drill out holes then back them with washers and nuts, this way if i ever want to De Eleanor my car it is not years of sanding/grinding old filler off, what do you think. get a bolt with a big washer attached and then just use fiberglass resin to attach the bolts?
