351 w + fuel injection - Vintage Mustang Forums
Old 12-26-2007, 05:16 PM   #1 (permalink)
is it even possible to get a 351 w stock fuel injection manifold to fit on a 67 coupe?
see below my engine with the 4 v carb and 3.5 in air filter, there is only like 1/2 inch clearance to the stock hood, i am going with an eleanor hood but i don't think it will give me more than another 2 inches
onegreedy67 is offline   Reply With Quote
Old 12-26-2007, 05:35 PM   #2 (permalink)
Send a message via ICQ to TheShagg Send a message via AIM to TheShagg Send a message via MSN to TheShagg
if that is indeed a 351w intake, and its too tall, you might try a holley upper, I believe the systemax fits it.
What's a bolt on
- Word to yo mutha.
TheShagg is offline   Reply With Quote
Old 12-26-2007, 05:40 PM   #3 (permalink)
what about the trick flow
looks alot shorter and cleaner
Old 12-27-2007, 12:21 PM   #4 (permalink)
buening's Avatar
What is your budget like? The new BOSS EFI system is damn sweet if you can afford it. Another option would be getting a Spyder intake (like yours with injector bosses welded in) along with a carb-style throttle body and a megasquirt ECU. I haven't seen any long runner type manifolds used but I do know the Trick Flow units are not as tall. The stock truck units are way too tall unless you have a large cowl hood. Even then the performance hit is not worth the conversion.
70 Mach 1 - 351w/T-56
70 SportsRoof - 302/C4
05 F150 FX4
06 BMW 530xi
T56 Conversion Thread
Custom Motor Mount Build Thread
buening is offline   Reply With Quote
Old 12-27-2007, 02:39 PM   #5 (permalink)
The Trickflows will fit under a stock 94-95 hood which has less room than our cars, so it'll fit. A truck 351W EFI intake won't even fit under a foxbody hood, by a long shot, and those have more room than a vintage stang. The 351W truck lower is a beast, so Shagg's idea of swapping on a shorter corresponding 5.0L upper seems pretty interesting.
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
gotstang is offline   Reply With Quote
Old 12-27-2007, 02:46 PM   #6 (permalink)
buening's Avatar
http://cgi.ebay.com/ebaymotors/Trick...spagenameZWDVW
05 F150 FX4
06 BMW 530xi
Old 12-27-2007, 02:50 PM   #7 (permalink)
buening's Avatar
Originally Posted by gotstang
TThe 351W truck lower is a beast, so Shagg's idea of swapping on a shorter corresponding 5.0L upper seems pretty interesting.
Like this?
05 F150 FX4
06 BMW 530xi
Old 12-27-2007, 03:46 PM   #8 (permalink)
willzee's Avatar
Send a message via MSN to willzee Send a message via Yahoo to willzee
If you were to buy the upper and lower intakes like these, what else would you need for a full conversion? Sorry for the noobish question, I'm just not familiar with how it all works.
1968 Coupe, 351W 2V, Cragers, being "restomored"
"Real courage is bein scared, but saddlin up anyways."
--John Wayne--
"The difference between fiction and reality? Simple: fiction has to make sense."
--Tom Clancy--
willzee is offline   Reply With Quote
Old 12-27-2007, 06:38 PM   #9 (permalink)
just a guess but
fuel injectors
fuel rail
fuel pressure reg
fuel pump
wiring harness,
computer
throttle body
mass air sensor
i am still wondering how the computer would know timing and rpm if i am using a msd distributor
anyone want to chine in and let me know what i am missing?
Old 12-27-2007, 10:53 PM   #10 (permalink)
htwheelz67's Avatar
no stock style 351w efi intake will fit under a stock hood unless you do drop motor mounts and mill the upper and lower intake, the mass flo efi will fit and most 4bbl throtlebody conversions based on the torker 2 or vic jr will fit, the holley commander tbi will fit as well and looks like the boss efi will as well but they are tbi style, f.a.s.t has a new one comming out as well.
htwheelz67 is offline   Reply With Quote
Old 12-28-2007, 12:04 AM   #11 (permalink)
out of all the throttle body versions which one is easiest to make work
Old 12-28-2007, 10:12 AM   #12 (permalink)
htwheelz67's Avatar
Just about any of them will fit fine, if your talking about simplicity and self tuning the mass flo efi I hear is the way to go, I may be going that route myself. If your good at wiring then you can buy a computer and sensors and all related stuff and make your own, single plane efi conversion manifolds are available, also holley makes a universal multiport kit that has a lot of whats needed in a kit but just about all except the mass flo are speed density so you will have to tune it with a laptop.
The TBI systems are cheaper and easier to install as they bolt on your existing 4bbl intake like the holley projection, boss efi etc....
the projection will require tuning but the boss efi has a "self tuning " speed density computer as the new fast system will.
my 67 http://htwheelz.smugmug.com
