Low Brake Pedal - Vintage Mustang Forums
Old 01-03-2008, 03:27 PM   #1 (permalink)
I have a disc brake swap on the front done with GM calipers, stock rear drums, and a 83 Ranger Disc/Drum MC 15/16 bore size and an adjustable valve on the rear brakes. The system is bleed as well as the MC. Pedal does not work till it is just above the floor. Any ideas?
65 289/T5 Front Bench Seat
Mels65 is offline   Reply With Quote
Old 01-03-2008, 03:30 PM   #2 (permalink)
White Elephant Guy
obsidianspider's Avatar
Send a message via AIM to obsidianspider Send a message via Yahoo to obsidianspider Send a message via Skype™ to obsidianspider
Are you using the stock MC pushrod?
Todd Dietrich - '66 T-Code Fastback, '07 GT/CS Coupe
VMF Facebook Group
obsidianspider is offline   Reply With Quote
Old 01-03-2008, 03:39 PM   #3 (permalink)
Yes I am using the stock push rod from the single manual MC.
Old 01-03-2008, 03:59 PM   #4 (permalink)
Stroked66's Avatar
Make sure rear drums are adjusted so they have a constant slight drag. Then check pedal again.
Stroked66 is offline   Reply With Quote
Old 01-03-2008, 05:07 PM   #5 (permalink)
The rear brakes adjusted tight againist the drums and there is no change in the pedal.
