Best Heads for 302/5.0 - Vintage Mustang Forums
post #1 of 24 (permalink) Old 06-12-2009, 01:17 PM Thread Starter
Mustanggoins's Avatar
Hi,
I have a 302/5.0 HO in my 64 1/2 Mustang that came out of a 93 stang with 37K miles. For the most part the engine is stock. I did put a E303 cam with Edelbrock RPM manifold with 4 barrel carburetor. I would like to change the heads and get the most bang (HP) for the bucks. The engine runs very strong, but I would like to have a few more horses under the hood. I really don't want to mess with the bottom end, but anything else goes. Thanks in advance for any ideas you might have.
Doug
Doug Goins
64 1/2 Mustang Poppy Red Convertible
93 500SL Mercedes Benz
00 Harley Davidson Fatboy
09 Buell Ulysses
07 Harley Davidson Ultra Classic/Trike Conversion
Mustanggoins is offline
post #2 of 24 (permalink) Old 06-12-2009, 01:44 PM
TFTW FTW!
67 coupe Turbo Blow-thru 351w, C4, 8.8 http://www.cardomain.com/ride/2435094
brianj5600 is offline
post #3 of 24 (permalink) Old 06-12-2009, 02:51 PM
v8only's Avatar
by far, the most popular for the 5.0 engines seem to be the afr 165/185 heads...
-66 mustang 5.0 custom comp cam roller, edelbrock performer heads, airgap/670 carb,holley blue pump,2005 mustang discs, t5z trans with clutch cable, 130 amp taurus alt. 1996 explorer 373 8.8 rear, open tracker roller suspension, solid adj strut rods and more
-72 maverick 302 undergoing FULL resto
v8only is offline
post #4 of 24 (permalink) Old 06-12-2009, 03:30 PM
I had essentially the same setup as you except for EFI... the engine made 231 rwhp.
Now it's been stroked to 331, AFR165s, 1.7 roller rockers, E303 cam and EFI. It does 107.5 MPH in the quarter mile. I don't have actual dyno numbers yet, but according to Virtual Engine 2000, it should be about 313 rwhp / 356 SAE hp.
AFR 165s are a bolt on, the 185s have 2.02" intake valves and may require notching your pistons... Both RHS and AFR suggest the 1.94 intake valve on a 302.
http://home.comcast.net/~stangg/vmf/stangg_516_1_sig.jpg>'68 Highland Green fastback clone. 331 EFI, AFR heads, tube chassis, Cobra brakes, Fox rack & pinion steering,T5z, 8.8" Auburn limited slip w/ 3.27:1 rear gears, triangulated 4 link, QA1 coil overs, run once in the 1/4: 13.3 @ 107.5
stangg is offline
post #5 of 24 (permalink) Old 06-12-2009, 08:24 PM
Tims65's Avatar
I think the AFR 165's are the top seed for your application. 185's would be too big for the CID and cam.
Tim
'65 2+2
347 - Holley DP - 471 fwhp
JBA shorty's, 2.5" tubes, Dr Gas X-pipe
T-5 world class 5 speed, w/ .80 OD
9" with 3.70's & T-loc
4 wheel Wilwood disc brakes
17" CL-205's, 225/45 & 255/40
TCP/Global West suspension
OpenTracker roller spring perches
subframe connectors, Panhard bar
TCP manual rack & pinion
Power door/window locks w/ keyless entry
Driven, not pampered
Tims65 is offline
post #6 of 24 (permalink) Old 06-12-2009, 11:36 PM Thread Starter
Thanks for all the input, seems like the ARF 165's are the best fit. I'll start rounding up the things I need to make the change.
Doug
Doug Goins
09 Buell Ulysses
post #7 of 24 (permalink) Old 06-13-2009, 12:49 AM
daisy0504's Avatar
Best head I would say afr165. Best bang for the buck would be gt-40 or gt-40p, if they will work with your exhaust. Both of these are iron not aluminum like the afr. Me if I were spending the money on heads I would splurge for the afr's, unless I found a great deal on some used gt-40's
67 Fastback,,t-5, 289 edelbrock performer heads, edelbrock f4b intake,holley 650 dp,comp cams 31-226-3, factory air and powersteering.
daisy0504 is offline
post #8 of 24 (permalink) Old 06-13-2009, 12:50 AM
zray's Avatar
Doug
great choice. let us know how you like them.
Z.
zray is online now
post #9 of 24 (permalink) Old 06-13-2009, 12:57 AM
68EFIvert's Avatar
+1 on the 165's. That is what I am running and they work great. I put down over 400 at the wheels when I had my original tune. I only took it up to 5200 rpm and that was with a vacuum leak on the intake. I think I should be about 430 now that it runs good. I chose the 165's because I did not want to notch the stock pistons and I will not spin it to the rpm's that the 185's will give me a big benefit. I also have an E cam. Good choice on going with the 165's!
Darreld
1968 Convertible
333 with 555 rwhp and 486 rwtq, EFI, Vortech V2 trim blower with 11.5 lbs of boost, H2O/Meth Injection, T56 6 speed, JMC clutch, Steeroids rack, Ron Morris Front and TCP G-bar Rear Coilovers, Cobra brakes, NewGen wheels. Basically a money pit. http://www.youtube.com/watch?v=zrqA9...ature=related#
68EFIvert is offline
post #10 of 24 (permalink) Old 06-13-2009, 10:42 AM Thread Starter
Thanks to all.
Should I use 1.6 or 1.7 roller rockers?
Doug Goins
09 Buell Ulysses
post #11 of 24 (permalink) Old 06-13-2009, 01:49 PM Thread Starter
Can I use my stock push rods or do I have to purchase hardened ones and is so what length?
Doug Goins
09 Buell Ulysses
post #12 of 24 (permalink) Old 06-13-2009, 05:41 PM
Administrator
68fastwilliams's Avatar
Check this article out. Exactly what you are looking for.
http://www.carcraft.com/techarticles...dup/index.html
68fastwilliams is offline
post #13 of 24 (permalink) Old 06-13-2009, 06:00 PM
68EFIvert's Avatar
I used 1.7 and was able to use the stock length push rods. I did get new pushrods though.
Darreld
1968 Convertible
post #14 of 24 (permalink) Old 06-13-2009, 07:01 PM
sportsroof69's Avatar
ALWAYS check the pushrod length if your using a roller rocker. It's easy to do, and can save you some headache on wearing out your valvetrain in a hurry. The length checker tool is like $8.
sportsroof69 is online now
post #15 of 24 (permalink) Old 06-13-2009, 10:19 PM Thread Starter
Thanks you all for the information, it really helps. One final question, heads for Stud or Pedestal mount rockers?
Doug Goins
09 Buell Ulysses
