» Network Links
»Super Springs
Old 08-23-2009, 01:27 AM   #1 (permalink)
ripped's Avatar
Default Front (big) disc brake conversion question - track width?
I am wondering for those of you who have done a big brake conversion;
Does the conversion change the front track width??
For example the rear wheels are pushed out about 3/16" more with the additional thickness of the disc brake hat, compared to the drum (thinner)
I would assume the same thing happens on the front.
I have limited clearance on the tire to fender, so I want to be careful and do my research before biting the bullit (so to speak)
ripped is offline   Reply With Quote
Old 08-23-2009, 01:48 AM   #2 (permalink)
Send a message via AIM to Black_67stang
It really is going to depend on which kit you use. I used the Mustang Steve 13 inch front disc kit and it did not affect my track width at all (went from drums) .
Zach
1967 coupe- Keith Craft 306 street/T5z with Pro 5.0. Arning Drop/ Bilsteins/ cut 720's up front and 4.5 mideyes out back. 13 inch Cobra discs
http://www.sounddomain.com/ride/2236002
Black_67stang is offline   Reply With Quote
Old 08-23-2009, 07:49 AM   #3 (permalink)
Shaun's Avatar
Yep, +1, it is going to be down to the kit you use. Some kits use hubs that push things out (Wilwood), some use factory track width hubs (Baer and my kits).
Some kits need spacers so the wheels clear the calipers, some don't...
Thanks,
Shaun
www.streetortrack.com
Shaun is offline   Reply With Quote
Old 11-20-2009, 02:07 AM   #4 (permalink)
ripped's Avatar
After a long wait the brake kit arrived yesterday, picked it up today and got one side installed. It's a very well put together kit. Some little mods, which I'll explain later.
Old 11-20-2009, 09:57 AM   #5 (permalink)
musgofasta's Avatar
Holy Crap - That's riduculously cool. I'm not normally a fan of the bright painted calipers, but that's freaking awesome. Huge Rotor, Huge hat.
What rims are those?
Nice work!
Must....Go.....Faster!
1967 Mustang Coupe - "Legend Lime"
Warmed-over Original 289 & Leaky C4
JSHarvey-modded strut rods, DazeCars Roller perches
Roller UCAs and LCAs, Homebent Subframe Connectors,
4.5 Mid-Eyes, '05 V6 Wheels
Explorer Junkyard 3.5" Aluminum Driveshaft
Explorer 8.8 Rear End - 3.73 LSD, Factory Rear Disc
musgofasta is offline   Reply With Quote
Old 11-20-2009, 10:24 AM   #6 (permalink)
buening's Avatar
Nice looking brakes! Looks like the Baer shelby brake kit.
What bracket kit did you use or are they custom?
70 Mach 1 - 351w/FMX
70 SportsRoof - 302/C4
05 FX4 F150 - Fully loaded baby!
06 BMW 530xi
buening is offline   Reply With Quote
Old 11-20-2009, 10:32 AM   #7 (permalink)
buening's Avatar
Ah, I see Shaun's kit has the brackets necessary.
Baer Brakes EXTREME-PLUS front kit with SHELBY caliper-4261142
06 BMW 530xi
Old 11-20-2009, 11:19 AM   #8 (permalink)
ripped's Avatar
It's actually this 13" kit (if I remember correctly)
Baer Brakes 6 piston FRONT Pro-Plus kit - 4261218
with the upgrade to the shelby caliper
going to the 14" wasn't worth the 1200$ for me.
It would fit inside my rim, though.
With the thicker baer hubs, I had to machine out some of the inside of the hub of the wheel. Otherwise it was high centering on it. This was easy, and is really only a retainer lip for the center caps, which I do not use on the front (beacuse I'm using a modern mustang wheel on a vintage 'stang)
Old 11-20-2009, 12:12 PM   #9 (permalink)
supershifter2's Avatar
i use Wilwood rotor hats and they are 1/4" thick at the wheel mounting surface.
supershifter2 is online now   Reply With Quote
Old 11-20-2009, 02:58 PM   #10 (permalink)
Shaun's Avatar
Yippeee! Finally!
Looks awesome.
Thanks,
Shaun
Old 11-20-2009, 04:59 PM   #11 (permalink)
ripped's Avatar
Originally Posted by Shaun View Post
Yippeee! Finally!
Looks awesome.
Yes FINALLY
They are really nice, though, and baer's kits are top notch.
Now after waiting this long, I need some California or southern US VMFers to blow some warm weather up here, so i can test the brakes out soon!
Old 11-20-2009, 11:19 PM   #12 (permalink)
fordrule's Avatar
Send a message via AIM to fordrule Send a message via Yahoo to fordrule
ever thought of using us brake ? the ones that are offered in summit and speedway? i heard they are comparable to willwood
fordrule is offline   Reply With Quote
Old 11-23-2009, 01:08 AM   #13 (permalink)
ripped's Avatar
No, I don't know anything about US brake
I bled the front brakes tonight.
It was a bit confusing, as we thought that the caliper body was leaking.
Turns out that just loosening the bleeder screw allows fluid to leak from the top of the caliper all the way down to the bottom. It appears like a problem with the caliper, but just by using a rag around the bleeder screw, stops the fluid dripping down.
So after that was determined, we went on bleeding and tapping the (big) calipers for air bubbles.
A couple small leaks at the bracket to flex lines connection, which were retightened.
Then we bled a little more to check for air.
Looks okay, but I am going to leave it overnight and see if any leaks present themselves on the garage floor.
Weather is not going to be good for a while, so I am not too sure, when I'll be able to test and break-in the brakes.
I'd like to have a couple good sunny days to make certain that everything is okay.
Old 11-23-2009, 08:30 AM   #14 (permalink)
Shaun's Avatar
When I do any brake work, I always recruit a helper to STAND on the pedal as hard as possible while I check EVERY fitting for leaks.
Unless its a gaping hole you won't see a leak by letting it sit but you should see one if the brake pedal is applied hard.
Thanks,
Shaun
Old 11-23-2009, 10:30 AM   #15 (permalink)
ripped's Avatar
Yeah, we kind of did that, but I found on the last go round, when I did the front brakes (stock calipers) the banjo bolt washers were seeping. It was not real apparent when bleeding, but overnight there was a puddle under both sides of the front. I had to replace the banjo bolts and washers.
Brake pedal feels firm, but there is definitely a little more travel. I assume that with the 6 pistons, the modulation will be better.
With the single piston caliper, the brakes worked well, but the modulation under partial braking was not that good.
weather is forcast to be good (better) for the weekend. I am hoping this holds and that I can get a day or two of testing in
