Residual pressure valve removal? - Vintage Mustang Forums
post #1 of 7 (permalink) Old 08-26-2009, 02:42 PM Thread Starter
ripped's Avatar
I have a maverick master cylinder on the 'stang. With the rear discs, I don't need a residual pressure valve.
How do I remove the one that is in there (if it is)?
Project 487 Super Snake - '67 Shelby GT500 Pro Touring Beast
Thunder - The Restoration Video From Start To Finish - 6 1/2 Years in Four Minutes
ripped is offline
post #2 of 7 (permalink) Old 08-26-2009, 08:06 PM
Red66GTCoupe's Avatar
Most drum/disc systems have a junction block not in the MC. I'm not familiar with the maverick mc though. All you need to do if it's a junction block is take the nut off the front and take out the plunger and springs and put the nut back on. Now it just becomes a t-fitting.
1966 GT Coupe - See it here>>> My 66 GT
1989 GT Convertible - More mods than my 66! Click it>>>My 89 GT
1999 Powerstroke>>>>>>Monster Truck
2002 Mercedes E430 SE
Red66GTCoupe is offline
post #3 of 7 (permalink) Old 08-27-2009, 02:56 AM Thread Starter
ripped's Avatar
thanks, I was under the impression that some m/c had residual valves built into them
ripped is offline
post #4 of 7 (permalink) Old 08-27-2009, 07:23 AM
ynned's Avatar
Yes, they do. Many service replacements, however, don't. The flare seat can be removed from the MC by turning a small screw into the orfice, then pulling the entire fitting out.
Here's the seat and valve removed:
Here's a (poorly focused) picture of the valve in the MC after the seat was removed:
Here's an MC with no valve after removal of the seat:
The first MC was from a '67 Mustang, either original, or at the newest from the mid-seventies.
The second MC was a NAPA service replacement for '75-'79 Granada purchased around2004-2005.
As you can see, although the Granada had rear drums, there was no res pressure valve. I don't know how one might figure out if you have the valve or not without physically pulling the seat out. As with most things Ford, nothing is clear or easy.
Dennis Harrelson
65 2+2, owned since '72
Lots of mods, now just another sad project hoping for resurrection.
ynned is offline
post #5 of 7 (permalink) Old 08-27-2009, 02:44 PM Thread Starter
ripped's Avatar
thanks
that answers the question
ripped is offline
post #6 of 7 (permalink) Old 08-27-2009, 04:36 PM
Good post Dennis. I went through this a few years ago. I ended up with a master cylinder off a 1992 Dodge Caravan. I pulled the brass flares out and there was nothing behind them.
67 coupe Turbo Blow-thru 351w, C4, 8.8 http://www.cardomain.com/ride/2435094
brianj5600 is offline
post #7 of 7 (permalink) Old 08-29-2009, 01:57 AM
Good stuff to know. Thanks for the post Dennis.
