Need to raise the air cleaner a bit? - Vintage Mustang Forums
Old 10-04-2009, 08:10 PM   #1 (permalink)
Default Need to raise the air cleaner a bit?
Forgive my stupidity as I have never had this problem before now. I am using a braided fuel line from the fuel pressure regulator to the edelbrock 600 and my ford racing air cleaner with a k&n filter is sitting a bit crooked because it hits the braided line going into the side of the carb. Is this what I need to fix the problem?
http://www.summitracing.com/parts/SUM-239000/
gwstang is offline   Reply With Quote
Old 10-04-2009, 08:45 PM   #2 (permalink)
Don't know about the diameter of that ring but if the hold down threaded rod has an extra 1/2" on it, should be fine.
Just be careful the first time you close the hood.
5F07C ready for body and paint.
Patches is offline   Reply With Quote
Old 10-04-2009, 09:17 PM   #3 (permalink)
Just some guy
GypsyR's Avatar
Default Re: Need to raise the air cleaner a bit?
I had a somewhat similar problem with an Edelbrock and a line something like one of these worked for me. Summit part
It tucks close to the carb an allows you to attach your fuel line/filter down and away from the aircleaner.
11. If thou be not absolutely sure of thy facts, thou shalt Google before posting thine answer.
GypsyR is offline   Reply With Quote
Old 10-05-2009, 03:37 AM   #4 (permalink)
thanks, I'll check the rod to be sure.
Old 10-05-2009, 03:38 AM   #5 (permalink)
That's an interesting alternative, thanks!
Old 10-05-2009, 07:02 AM   #6 (permalink)
6t9mach1's Avatar
If you've got a stock intake manifold and the hood clearance I would just use the air cleaner spacer.
~Ryan~
1969 Mach 1- 357w: 11:1 compression, ported Canfield heads, FTI billet solid roller cam, Vic Jr., 850 Mighty Demon
Full manual AODE transmission w/ 9.5" Art Carr converter; 4.11 detroit locker
http://www.cardomain.com/ride/2554478
6t9mach1 is offline   Reply With Quote
