» Network Links
»Super Springs
Old 11-19-2009, 03:58 PM   #16 (permalink)
Originally Posted by Red66GTCoupe View Post
Turd: Im surprised you had problems with the fit of the Branda apron. I have a Branda apron that required very little trimming. The only mod I needed was at the bottom of the headlight buckets. You sure your car/frame is straight? Just a thought.
Yeah. What mine was doing is really hard to explain. It was bottoming out on the lower core support in a way that trimming would not have helped. I tried to explain it on the other page. The other gripe I had was it was it looked like two different people trimmed it. 100% different from side to side.
I also see you have the non bumper piece so I can only assume it uses a different mold.
Originally Posted by 66Restomod View Post
The fiberglass apron I got from Mustang Plus fit perfect. Had to drill holes to mount it but that was not a big deal at all.
I would think the time involved to do a mod of your steel apron would be quite a lot.
Not worried about the time. I really just wish I would have followed through with it from the begining like I wanted to. I just want the best possible results. My body guy wanted to cut the glass one in half and then section the center to allow it to wrap around the core support like it should. End result is that I will have something no one else has(remember the aluminum insert), and it will be stronger without the eventual fibergass cracking that I am sure was to happen. Hell, it already had a ton of stress cracking just from trying to get it fitted.
1989 Coupe Black X41 code 2200 original miles
1984 GT350 Turbo T-top #1978
1984 Turbo GT 418rwhp 4 banger
1966 Coupe black on black TW headed 302, AOD, 8.8 , Bullitts, Cobra brakes, Cowl hood. New project and usually giving advise, not used feeling like an idiot newbie
Progress pictures ;
http://s192.photobucket.com/albums/z253/GT350RR/66%20coupe/
Turdburgler is offline   Reply With Quote
Old 11-20-2009, 02:56 AM   #17 (permalink)
JonK's Avatar
The metal one i posted with the license plate area cut out and surround tack welded in took all of an hour. Cutting wheel, cardboard template, cut/bend scrap steel, tack weld, done except seam bondo and paint.
Jon
"If it ain't broke, I haven't fixed it yet"
-Jon-
1967 Coupe 333ci CandyApple Red w/red int., AOD, 9" 3.50:1, Front PDB
'09 Warriors In Pink V6 w/glass roof - wife's Stang
JonK is offline   Reply With Quote
Old 11-20-2009, 07:13 PM   #18 (permalink)
Red66GTCoupe's Avatar
Have you contacted Branda about the fit? They have some of the best fiberglass on the market. Maybe you just got a bad one?
Red66GTCoupe is offline   Reply With Quote
Old 11-20-2009, 07:29 PM   #19 (permalink)
ynned's Avatar
I know it's kinda late in the thread, but I just stumbled on this pictorial showing the fabrication of one using the original bumper and fabbing the rest from sheet. Pretty nice job.
Dennis Harrelson
65 2+2, owned since '72
Lots of mods, now just another sad project hoping for resurrection.
ynned is offline   Reply With Quote
Old 11-20-2009, 10:54 PM   #20 (permalink)
fordrule's Avatar
Send a message via AIM to fordrule Send a message via Yahoo to fordrule
some i found
fordrule is offline   Reply With Quote
Old 11-21-2009, 04:08 AM   #21 (permalink)
Wow, nice find. They do some crazy nice work at that shop!
Tungsten is offline   Reply With Quote
Old 11-21-2009, 07:38 AM   #22 (permalink)
ynned's Avatar
Yeah, I found it looking for info on block sanding, of all things. Many good ideas and techniques. I only poked around the site for a few minutes, but there's a ton of stuff there.
Old 11-23-2009, 11:07 AM   #23 (permalink)
Agreed. Very cool website. I have been staring at it for days..........
Progress pictures ;
Old 11-25-2009, 02:17 PM   #24 (permalink)
Stanger'66's Avatar
I decided to give it a try a couple years ago. I hadn't heard of anyone doing it at the time(although I'm sure they had), but I couldn't find any info on it. Here is the short writeup I did on it.
All-Metal '66 GT 350R Street Valance
Stanger'66 is offline   Reply With Quote
