i am converting my 65 from a c4 to t5 but i tried to install the clutch petal and it overlaps the brake petal. do i have to get another bracket and brake petal? i am using a 65' clutch petal. also i am using a clutch cable conversion how would i use a return spring?
Are you trying to use the brake pedal from an automatic? The automatic brake pedals are wider than the ones from the clutch set-up. I believe the pedal support bracket should be the same. You will also need the clutch pedal stop and clutch return spring bracket.
If it's stuck, force it. If it breaks, it needed replacing anyway!
66 Mustang Coupe
* 289 with C4 automatic
* Factory front disc brakes
* Tahoe Turquoise
ok that makes sense. i was reading that that thick spring that hooks to the clutch pedal was just a "helper spring" not a pedal return spring is this true?
You MIGHT not need that spring if you have a diaphragm clutch. You can use the auto brake pedal if you cut it down and put on a rubber pad for a manual trans brake pedal.
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
You don't need a return spring with a cable clutch if the setup is designed and adjusted properly. You would only need a return spring if the end of the cable on the clutch pedal is not captured.
I am the member formally known as RonK.
1957 T-Bird
1966 Shelby G.T.350H
1966 Mustang Fastback Restomod under construction
+1 No return spring needed. With a properly adjusted diaphram style clutch set up there is a slight preload on the clutch fingers. There should be no free play in the pedal at rest. This is according to the Mustang steve cable kit instructions. It says to take out the return spring. I am also still in the process of the T-5 conversion. Just life is getting in the way (Newborn future stang lover) that is.
man, for most of us who are old enough to remember embarking on major projects pre message forums...I remember getting lost and giving up more than once!
-66 mustang with gt40y crate motor,t5 with sn95 clutch cable,duraspark, bullitt wheels, 130 amp taurus alt. 8.8 coming soon
-72 maverick 302 undergoing FULL resto
-03 Hemi ram
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
