Never heard of this brand.
Personally I would step up and use the Heidt's or TCI coil over design.
I have install several Heidts Superride IIs and the crossmember is super easy to install.
Phil
PS I think Rod and Custom Motorsports also make a coil over style now.
I also went with the Rod an Custom system. They have coilovers for their setups as well. That's what I went with. The instructions are very clear and they are helpful over the phone.
1. More engine room - Mustang II types and SLA conversions will give you more room. They usually require some level of surgery and may not be easily reversed.
2. Improved Handling - Mustang II geometry? Some are happy with it. Heidt's, R&C and others are reputable. CPP is a newer Mustang offering (see Coleman's incredible build). Personally, I'd never use a MII suspension...but my goals may be very different than yours...I'm building one highly modified, track car and one minimally modified street/vintage racer. The first will use that absolute best (and expensive)...Griggs Racing (Griggs Racing Products). The second will use some components from Open Tracker, Street or Track, Global West to adhere to Vintage racing requirements.
I would hesitate on this product, just because it appears new. Hopefully, you can find someone who has implemented it and can advise you.
Good Luck!
1965 Fiberfab Street E/T, Tuck & Roll Leather Interior, Chrome Roll Bar, Fiberglass Deck Lid & End Caps, 66 Pontiac GTO Sequential Tail Lights, Shaved Door Handles, Gas Filler and Trunk Key, Doug Thorley Show Tubes, Shelby 66 Quarter Windows and Scoops
From what I recall Heidts has issues with their kit and 351 engines. Rod and Customs kits seems to be the benchmark for the MII styled suspensions. If you go with and MII setup, get one that uses true coilovers since you'll have an easier time tuning and setting ride height. Also notice that in linked kit that you need to use drop spindles just to maintain stock ride hieght. If this kit was specifically designed for a Mustang, then they would have dropped the spring bucket deeper into the lower control arm so that drop spindles wouldn't be required.
'68 Highland Green, custom built tubular chassis, Fox rack & pinion steering,'89 HO/331, Cobra intake, E303, AFR 165 heads / T5z spec transmission,
8.8" rear end w/ 3.27, Auburn limited slip, triangulated 4 link, QA1 coil overs front and rear, Cobra 4 wheel Disk brakes. '01 Silver Bullit wheels.
Was a coupe, now sports a fastback roof. First run 13.3 @ 107, looking for 12's...
Mustang II - a just-as-bad suspension geometry as 65-73 factory suspension with small rotors as well......
Not a big fan, as you can probably tell.
i disagree, I am a huge fan as you can tell. Maybe the M2 is not the best on a road track or maybe it is (i dont know). but it is on the street for regular driving. But you should draw your own conclusion, this debate is an old one and it will be around a long time. anyway i would stick with Heidts or Rod and Custom if you choose that route.
68'COUPE
5.0 4BBL
T-5
9" 3.25 TRACLOCK
Dakota digital
Magnaflow stainless, Heidts M2 front end, Flamming river tilt
Your goals should give you your answer. I have installed R&C Mustang 2's and love them. If you are planning on a Modular, or biggie engine and need the room, then its the way to go. If you give R&C a call and tell them what engine/tranny you are planning on using, they can adjust the cross menber and offer helpful advice (and I would plan the complete build first). On the flip if I was planning on a small block, "to me" I am just as happy using the original type suspension some cheap modifications like the "Shelby drop" with a set of roller perches and a good alignment. This in itself will make a world of differ in how the car drives and handles and save you about 1500 bux. As far as the kit you mentioned, why not spend your money with someone that has been around and that will be there to answer your questions, should you have an problem.
"The important thing is not to stop questioning. Curiosity has its on reason for existing"..........Einstein
65 Fastback 66 Vert 67GT500E (re-creation) 68 Notchback Racer 68 Vert 68Gt500KR 71J code Mach One 72 Mach One 73 Mach One
you will notice the only ones bad mouthing a mustang II suspension are those who dont have one...all of us who have one love it...makes you think doesnt it?
66 mustang coupe,Heidts Mustang II front end 4.6L DOHC mod motor, T45 transmission, 8.8" disc rear end, twin turbo system in progress, and a ton of other crap
Actually there was a guy or two in a previous thread that had performed the MII conversions and said they wouldn't recommend it unless you need the room for something like a Mod motor. I think it was due to the work involved.
Maybe one of these guys will chime in.....
Hey, it's you car. Do what you want.
If you want a Mod motor or a Boss 429, it's about the only choice you have.
oh, i agree, if you are happy with a small block...there is absolutley no reason to go with a MII front end...I wouldnt say the amount of work was all that bad myself, but then I have a ton more work than that going into my car, if you have a wide engine though...like you said, there really is no other effective choice, I will admit that the disk brakes and rack and pinion alone is worth the price...I paid something like 1600 for my heidts kit from an ebay distributor
+1 I went with basic mods above and got good results.
As far as the MII setups, I'd do one if I needed the room for a street driven car. I think they get a bad rap because MII & Pinto's are unpopular.
67 Mustang Convertible * Mild 5.0 EFI * AOD Transmission * 68 8" rear end * Aeroform R&P * Open tracker roller perches * Arning Drop * 560 LB 1" lowering front springs.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
