» Network Links
»Super Springs
Old 02-06-2010, 02:14 PM   #1 (permalink)
Default 65 Fuel Filler Neck Return Line Mod
Here is a mod I did on my filler neck about 1 year ago. It was never installed because I went a differnt route.
My original plan was to run a return line into the trunk via the drain hole on the driver's side trunk. The filler neck was cut so it could pass thru the rear panel. It would not go in with the AN fitting welded on. This project started becuase I was adding an electric fuel pump to my carbed car.
I am posting this just to give people an idea on how it can be done. In the end, I went with a fuel sender that had a return built in.
BTW, this is for sale if anyone wants it.
65coupei6_2 is offline   Reply With Quote
Old 02-08-2010, 06:40 PM   #2 (permalink)
I don't blame you for going a different route... I don't think I'd want a return line being fed by an electric fuel pump running through the trunk either. I'd imagine that if you've got a high flow pump that some amount of gas will spash towards the gas cap.
What a most folks do us run the return line through the tank drain bung, or plumb a return line into the fuel sender like you ended up doing ( me too ).
'68 Highland Green, custom built tubular chassis, Fox rack & pinion steering,'89 HO/331, Cobra intake, E303, AFR 165 heads / T5z spec transmission,
8.8" rear end w/ 3.27, Auburn limited slip, triangulated 4 link, QA1 coil overs front and rear, Cobra 4 wheel Disk brakes. '01 Silver Bullit wheels.
Was a coupe, now sports a fastback roof. First run 13.3 @ 107, looking for 12's...
stangg is offline   Reply With Quote
