dip stick plug for late model 5.0 - Page 2 - Vintage Mustang Forums
Old 04-03-2010, 10:39 AM   #16 (permalink)
Originally Posted by LastDeadLast View Post
I used a wooden dowel as well. It'll swell up and never leak.
-Shannon
Same here... did the wooden dowel 4 years ago and never a leak
JamesW's Website
JamesWnew is offline   Reply With Quote
Old 04-03-2010, 11:38 PM   #17 (permalink)
I drilled and tapped for a socket head plug.
JohnnyK is offline   Reply With Quote
Old 04-04-2010, 08:08 AM   #18 (permalink)
I also used a wooden dowel. No leaks here.
5.0 H.O. roller block,cast iron GT-40 heads, e303 cam, 1.7 roller rockers,RPM intake,600 holley dbl. pump,
duraspark ign.,FPA headers,and t-5 trans.
Paul
6t6red is offline   Reply With Quote
Old 04-04-2010, 04:01 PM   #19 (permalink)
Just some guy
GypsyR's Avatar
The last one I did I found one of those little steel rods that go on the drum brake wheel cylinders laying around. Tapered on one end and just about the right size. After checking the fit, I put some red LocTite on it and beat it into the block with a hammer. With care, you could potentially crack the cast iron this way. After letting it set up I ground the protruding end down flush. After painting the block it's invisible and I have no doubt is absolutely permanent.
GypsyR is offline   Reply With Quote
Old 01-11-2013, 10:03 PM   #20 (permalink)
is it a 3/8 dowel?
greenmacheen is offline   Reply With Quote
Old 01-12-2013, 07:02 PM   #21 (permalink)
MustangChuck's Avatar
Originally Posted by 50 Proof View Post
Anyone happen to know what size brass plug to use?
3/8" freeze plug, NAPA p/n 3812185. Cost is about $0.75 each. They are not usually stocked, so it takes a day or two to arrive.
A little silicone sealant on it before tapping it in is a good idea.
Chuck
Check out Popular Hot Rodding, Aug 2009, Pg 35, upper right corner!
My budget makes a shoe-string budget look like Warren Buffett's personal checking account.
1969 Mustang Fastback (work in progress)
(Pics Gallery)
1995 Mustang GT Convertible (daily driver)
1994 Mustang GT Coupe (donor car)
MustangChuck is offline   Reply With Quote
Old 01-12-2013, 07:42 PM   #22 (permalink)
j persons's Avatar
I used the 1/8" NPT tap method. The hole is actually a little large for a 1/8" tap, and the Allen plug will seat a little deep, but that won't hurt anything. Sealed the plug using Permatex #2. Locktite can loosen when heated, but Permatex is in there almost forever.
'97 TBird project. AED supercharger, forged bottom end. Runs high 11's, when it runs.
j persons is offline   Reply With Quote
Old 01-13-2013, 04:01 PM   #23 (permalink)
bartl's Avatar
If you use a tap, just pack the flutes between the cutting teeth with vaseline to catch the shavings and clean often.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 01-14-2013, 03:03 PM   #24 (permalink)
I tapped mine and used an oil gallery screw in plug. Block was bare at the time.
merfsiu is offline   Reply With Quote
Old 01-15-2013, 06:26 PM   #25 (permalink)
i used the Napa plug
Lucky66 is offline   Reply With Quote
Old 01-15-2013, 07:19 PM   #26 (permalink)
-Shannon
same here... worked fine for the last 7 years
JamesW's Website
Old 01-15-2013, 08:57 PM   #27 (permalink)
68_Jcode's Avatar
I used a tapered cork with some silicone, tapped it in and no leaks.
68 Fastback J Code: Acapulco Blue |347 stroker |AFR 185's| Air Gap| Hooker Comp's| Crane HI6 Ignition| T-5z transmission| JMC Hydraulic Clutch| SSBC Force 10| and the list goes on...
2007 GT: |Cervini C300 Build |5 Spd| 3.55 Axle| 18" Polished Bullets| Redfire| IUP|Crimson Red Leather| Comfort Group| Premier Trim| [color:red][/color]
68_Jcode is offline   Reply With Quote
Old 01-15-2013, 10:01 PM   #28 (permalink)
tx65coupe's Avatar
I tapped mine and put a threaded plug in it.
The wooden dowl does usually work fairly well.
The RTV doesn't usually last.
I bet the little freeze plug does work rather well.
1997 Cobra Convertible (stock)
1965 Mustang
Late Model 302 and T5 and Versailles 9 Inch
Edelbrock Heads, Cam, Intake, and Carb
JBA Headers and Dynomax Ultraflo Mufflers
http://forums.vintage-mustang.com/me...-100-1108.html
http://www.youtube.com/watch?v=LXk_MVV7V0g
tx65coupe is offline   Reply With Quote
Old 01-16-2013, 10:00 AM   #29 (permalink)
fordguy's Avatar
that's what i did also
66 mustang coupe
fordguy is offline   Reply With Quote
Old 01-16-2013, 11:08 AM   #30 (permalink)
Just some guy
GypsyR's Avatar
"Absolutely permanent" became unpermanent. I eneded up needing that 5.0 to go back into an EFI application. To remove the plug I used I pulled the pan (had to swap it anyway), heated the plug with a propane torch and knocked it out from the backside with a hammer and punch. Sure am glad I didn't tap the hole for threads or I don't know how I would have gotten the stock EFI style dipstick to seal correctly. Big gob of silicone or something similarly crappy.
