I'm installing a late model roller 5.0 into my '65 Mustang. How do I plug up the dip stick hole on the block? What do I use? Is there a dipstick plug I can buy somewhere?
Yes you can get a tap in plug at an auto supply, or use a tap and thread it for a threaded plug, or take a stub of wooden dowel and tap that in w or w/o silicone. Or just fill the hole with silicone.
I can no longer tell the difference, between what I never learned, and what has just plain been forgotten.
ahh Silicone, why didn't I think of that? I'm thinking I need some sort of overly complicated solution and didn't stop to think that it could be that easy. Thanks for the suggestions.
Do it the right way, go get a brass plug and tap it in.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
Low budget, low tech, wooden dowel is actually a v good method to use. Impervous to the oil & no metal shavings to deal with.
That or a plug, like a mini freeze plug(oil gallery plug) is slick.
You bring up a good point about metal shavings. Perhaps running a 1/8 NPT through that hole may not be a good idea. It's not a bare block. The engine is fully assembled. If I run a tap through that hole I'll possibly get metal shavings in the engine. I'll make a visit to the local napa or autozone and see if I can find a tiny freeze plug, otherwise I'll look for a wooden dowel or plug it with silicone.
I also used a wooden dowel. It swelled up and has not leaked. Simple. I didn't want to deal with shavings or anything. You can't see it. It blends in. It is cheap and it doesn't leak.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
