Edelbrock carburetor running rich - Vintage Mustang Forums
post #1 of 9 (permalink) Old 06-04-2010, 10:06 PM Thread Starter
Scottem's Avatar
Part # 1803 500cfm 4bbl
Symptom: Exhaust stings my eyes and really stinks badly.
I assume the carb is running rich and after adjusting the air/fuel screws on the front of the carb, confirming there are not gasket leaks, timing is good as is the vac gauge reading (18lbs). Adjusted the auto choke and its good. Condition persists..
Edelbrock says the primary jets on this carb (primary carb on a dual carb set up) are
Metering Jets: .086
Metering rods: .065 x 0.57
I have a tuning kit from Edelbrock.
Question: What size jet and rods should I run to make the rich condition go away?
Scotty
67 fastback
68 coupe
03 SVT Cobra
Scottem is offline
post #2 of 9 (permalink) Old 06-04-2010, 11:31 PM
wilit's Avatar
Every time I've read a thread like this, some guy always posts up, "What's your fuel pressure set at?" Apparently Edelbrocks are very sensitive to fuel pressure and should be set at 4.5 psi. Mechanical pumps can produce more than 4.5 psi, so it's a good idea to check it.
I have a similar issue with my Edelbrock, but I haven't taken the time to install my pressure regulator yet.
wilit is offline
post #3 of 9 (permalink) Old 06-04-2010, 11:46 PM Thread Starter
Scottem's Avatar
Running dual carbs the 6psi its currently at quickly lowers to less than 2psi til I pull a Dukes of Hazzard and turn on the electric pump.
Suppose its ok to go two steps leaner? The exhaust really stinks..
Scotty
67 fastback
68 coupe
03 SVT Cobra
Scottem is offline
post #4 of 9 (permalink) Old 06-04-2010, 11:53 PM
wilit's Avatar
I don't think the jets and rods have any effect on A/F ratio at idle. That's the job of the idle screws and idle circuit. The rods and jets only come into play once the throttle is cracked (at least that's my understanding of Edelbrock carbs).
wilit is offline
post #5 of 9 (permalink) Old 06-05-2010, 01:16 AM Thread Starter
Scottem's Avatar
A little background about the car.. Last summer a couple following me in their ragtop Saleen said they had to back off because my exhaust was making them sick and it stank something fierce. At a rest stop I asked some of my buddies to smell the exhaust as I worked the gas pedal a little. They had the same remarks, no doubt I had a rich condition. Dual carbs really are not worth the trouble.
Found a few issues tonight.
The fuel regulator doesn't work. The 6psi couldn't be adjusted (using a stock fuel pump) so the regulator will have to be replaced.
An attachment to the throttle on the primary carb wasn't allowing the throttle to return all the way. The throttle was cracked part way open (about 200-300 rpm worth). I suppose that means the car wasn't idling correctly? That in mind, I did the easiest thing and go "one step" down which Edelbrock says to install a different set of metering jets down to .067/ .055 After working the throttle a little bit (at 180 degree engine temp) it helped a little. The difference was noticeable but still stank remains.
I'll replace the fuel regulator and if the rich condition persists, then I'll goto a second step (replacing the primary jets and metering jets). Found two air/fuel screws were out of adjustment. That added 2.5 lbs of vac so i adjusted my timing which further lowered the idle speed.
At least I was able to reduce the idle speed from 1200 to 900rpm.
Scotty
67 fastback
68 coupe
03 SVT Cobra
Scottem is offline
post #6 of 9 (permalink) Old 06-05-2010, 08:14 AM
kenash's Avatar
Metering Jets: .086
You want to go leaner! That's the quick answer. Sounds a little "smart a...", I know, but this retort is as broad an answer as your question.
Having extensively tuned a 1405 (specifically), both on the road and chassis dyno,
I start out tuning carbs with:
1. attach a vac gauge, (manifold vac) to insure no leaks most street engines will be between 15-20 hg
2. insure your timing is within parameters most rigs run 12-14 deg.
3. attach a vac gauge ( manifold vac) with your idle at or near 750-900 (?) adjust each mix screw for the highest vac reading, all the while maintaining your desired idle setting.
4. Also, know there are two vac ports on that carb, OK 3, if you count the PCV port. One is full manifold and the other is timed" or "ported". As every engine is different, the choosing of which will depend on how your engine responds to the input. This is a whole other can of worms.
If you bought this carb new, you would have gotten a setup/install guide. In the back of the guide is a graph chart for tuning the carb's AFR. To go lean you select "X" metering rods and springs, to go richer, you selct these etc. If you don't have a guide, it is available on their site as a download in the technical section.
"No one" on this site can recommend specific rods and jets. I will go out on a limb and state that one would usually start by changing the metering rods. It's a case of knowing where the AFR goes "fat" (rich).
Each engine is different in too many ways for any of us to answer " What size jet and rods should I run to make the rich condition go away" again, the simple answer to your quest may be "go leaner".
Outside of many hours of road testing, a chassis dyno is your next best way to learn what your AFR is doing over a broad RPM range. Otherwise, buy an AFR meter on your own and have at it.
Good Luck!
Ken ..
64 1/2 Poppy Red too!, Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, MD
kenash is offline
post #7 of 9 (permalink) Old 06-05-2010, 02:01 PM Thread Starter
Scottem's Avatar
Great post! I am going leaner as outlined in the Edelbrock owners manual. Did one step leaner last night (just metering rods) and it helped so I'm going to a step two tonight (rods and jets).
I have a vac gauge installed on the car so I use that to set the mixture screws.
Scotty
67 fastback
68 coupe
03 SVT Cobra
Scottem is offline
post #8 of 9 (permalink) Old 06-05-2010, 02:59 PM
kenash's Avatar
"Scotty",
Now, you're are on the right road. Don't forget to document every adjustment you make. Start with the base line info, then add to it.
PlaySafe!
Ken ..
Severna Park, MD
kenash is offline
post #9 of 9 (permalink) Old 06-05-2010, 04:32 PM Thread Starter
Scottem's Avatar
Thanks much !
Scotty
67 fastback
68 coupe
03 SVT Cobra
Scottem is offline
