How to repair a crack in cylinder head? - Vintage Mustang Forums
post #1 of 16 (permalink) Old 06-23-2011, 01:59 PM Thread Starter
Has anyone had to repair a crack in a cylinder head before with JB Weld? The crack is under the valve cover between the rockers. Just wandering if it is probable for the JB Weld to hold, and exactly how to do it properly. I bought the head from a junkyard to replace the one I have and have done a good amount of work to it before sending it to a machinist who found two small cracks. He said the two cracks are shorter than an inch long, and probably not enough leaking through for it to have shown in the oil. I would appreciate any information on how to best fix the problem from those who have had similar issues they have dealt with. Thanks, Don
Don K is offline
post #2 of 16 (permalink) Old 06-23-2011, 03:40 PM
bbpschools's Avatar
i would probably either have it welded for real or a better option is to get a new one and take it to a machinist first to see if it has any problems.
1967 coupe 289 3 speed original interior
bbpschools is offline
post #3 of 16 (permalink) Old 06-23-2011, 04:32 PM
I won a special award
Maxum96's Avatar
If it's an aluminum head, it can be welded. If it's cast iron, the only way to fix it is to drop it into the nearest trash can.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression, Victor Jr. intake, solid roller cam with shaft mount roller rockers
Tremec TKO 5 Speed
Maxum96 is offline
post #4 of 16 (permalink) Old 06-23-2011, 04:37 PM
I've heard good stuff about JB on other forums. One guy had a Suburban that had a crank in valley area and was getting water in the oil. It was just a crunch repair but it lasted. Another guy ported a set of sbf heads and went through into the water jacket from the intake port. Used JB and ran the head for many years.
Not saying this is the correct way of doing it but it seems for temporary pinch repairs, it lasted like a permanent repair. Give it a try.
Tom
I'm not a complete idiot, pieces are missing.
Huskinhano is online now
post #5 of 16 (permalink) Old 06-23-2011, 05:00 PM
Lukesportsman's Avatar
JB Weld is GREAT stuff, but it WONT over come thermal expansion! So yes, epoxy up a perforated port, or a water jacket, but it won't fix a cylinder wall or a head that has overheated and cracked.
I agree with Maxum for 95%. The answer is yes a cracked iron head can sometimes be repaired. I said repaired and intentionally didn't say fixed. It must be done by a trained welder. Strip head in area of repair. Drill out both ends of crack. Bevel out the area along the crack. pre and post heat the head. And using the "proper" cast iron welding rod in a "good" stick welder your going to arc weld it back together.
chuck it and get a new head if it came from a junk yard, they may even have a 30 day exchange. If its a numbers matching 302 Cleveland head (which its not) then "maybe" its worth the effort. It will most likely fail again at some point. JHMO
69 351 TKO Sport Roof, Ride Tech coilover
70 557 PG Mach I tube chassis 2650lb
70 427 TKO Sport Roof, SoT full chassis to be
70 351 FMX Mach I
67 347 TKO Coupe SoT/CAT5
67 289 C4 Coupe stockish cruiser
69 460 TKO Vert, Mustang Plus Grab a Track
94 351 TKO AIX, Maximum Motorsports
01 5.4 4L80E Twins and CrMo caged
http://www.hubgarage.com/mygarage/LukeSportsman
Lukesportsman is offline
post #6 of 16 (permalink) Old 06-23-2011, 06:21 PM
Banned
The head can be heli-arced in place.
beechkid is offline
post #7 of 16 (permalink) Old 06-23-2011, 10:25 PM
need to have a good welder ,not jb, at a engine machine shopweld the head and remachine the head, you can fix a iron head. i have blown up many engines in my time,unless it is a total dessaster.
the fool is offline
post #8 of 16 (permalink) Old 06-24-2011, 01:31 AM Thread Starter
Thanks for all that have replied. I do intend on trying the JBWeld by drilling out the ends and grinding down the crack and filling it. I have seen it work for years on the outside of a block between the cylinders, and can not think of why it wouldn't work in the valley. The guy that did this has passed away, so I can not tap his brain for more info... Sure miss him in times like this; he was a motorhead pro.
Don K is offline
post #9 of 16 (permalink) Old 06-24-2011, 06:47 AM
ylexot's Avatar
Hope you like changing heads. Every JB Weld 'fix' I have seen that involves the water jacket has had a short life. Do yourself a favor and break with the $40 to get it welded correctly.
Formerly of the Permanently Addicted...
Let it be known that I do not street race or condone that sort of thing
- unless the 'b@stard deserves it.
Someone takes his pants off and the rafters knock
Rock is dead they say
Long Live Rock!
67 conv. 289 4spd(mine), 67 coupe 289 Export(swmbo's)
ylexot is offline
post #10 of 16 (permalink) Old 06-24-2011, 09:17 AM
When you tear it down again it will cost you more than the price of a replacement head and you WILL have to do it again! JB weld is a half arse repair at best and besides if that head is cracked there it most likely was from overheating and so it will likely be cracked in other places also, have you had it Magana fluxed? Cobbling such as that is done on old lawn mowers and farm-All tractors and has no place on a car, especially a Mustang!
2late is offline
post #11 of 16 (permalink) Old 06-24-2011, 10:39 AM
When youre putting a crank in that motor because the antifreeze that leaked through the gooped up crack wiped your bearings, you'll wish you had fixed it right or replaced it with a good head.
65 coupe GT Tribute 5.0L/5 speed
2001 Lightning #1757
Lightning is offline
post #12 of 16 (permalink) Old 06-24-2011, 12:43 PM
rsalway's Avatar
I have to agree with others. I am all for saving money and understand you have some time involved, but that is too risky.
Ryan
1967 Mustang Coupe. My first car.
302, Early 351W Heads, Windage Tray, Edelbrock 289 Performer intake, Holley 600 Carb w/1" spacer, T5 Transmission, NPD 1" Lowering Springs, 1" Mid-Eye Lowering Leaf Springs, 17" 04 Bullitts, 3.00 8" Rear, Granada Front Brakes. Still a lot of work to go and a lot of things to buy.
Need any graphic design work check out my site:
www.ryandaviddesigns.com
rsalway is offline
post #13 of 16 (permalink) Old 06-24-2011, 01:04 PM
are we talking about an uncommon, exotic head here like a date coded original Boss 302 or Boss 429 head?
or are we talking about a fairly common one like a 289 or 302 head?
Exotic one? take it off and get it welded properly.
Common one? buy another and transfer your parts to it.
HoustonGlock is online now
post #14 of 16 (permalink) Old 06-24-2011, 02:00 PM
I wouldn't spend the money rebuilding a cracked iron head.
I wouldn't waste the intake gasket or head gasket either.
Replace the head.
I am scared to ask if this car will be for sale soon.
Sense is not as common as you think.
17" MB Old School wheels from discount tire (a lot of people ask)
OCHOHILL is offline
post #15 of 16 (permalink) Old 06-27-2011, 10:13 AM
Hopefully you've fixed the problem that caused it to crack in the first place....
Unless it's some seriously special head, save your $$$ and replace the head.
19079 is offline
