Rebuilt my Holley carb, and now I can't keep her running. Help. - Vintage Mustang Forums
post #1 of 22 (permalink) Old 04-09-2012, 04:03 PM Thread Starter
TrueBlue's Avatar
I used a Holley TricKit and a Super Chevy (I know, I know) online rebuild guide to rebuild my 4160 four-barrel. Blew out all the passages, no leaks and all my gaskets were checked and double checked to make sure they were going on the right direction.
Now that it's on the car, she wants to start - and in fact will start if the pedal is floored - but won't stay running, choke open or closed.
Definitely could use some insight from the proverbial gray beards. Help!
-Tom
1968 Mustang Fastback
2015 Ford F150 FX4
2006 Mitsubishi Evolution IX
2002 Chrysler 300M Special
SchnorrCS: when people find out how into these cars I am, all the sudden they have/had one just like mine, but it was purple and had a hemi, and was a Shelby.
TrueBlue is offline
post #2 of 22 (permalink) Old 04-09-2012, 04:55 PM
Banned
Did you use any adhesives? they can obstruct passages
beechkid is offline
post #3 of 22 (permalink) Old 04-09-2012, 06:12 PM
burnout289's Avatar
Did you match up each gasket properly? I just rebuilt my 4160 and am dreading the day when I have to actually start it up. But with all the gaskets in that kit, I had to double-check each one multiple times (and am glad I took lots of pics taking it apart). Some of them are really similar but just one or two holes are different. From what I've read, that can make all the difference. I held up each old gasket to the light and went through each new one until I had all the holes lined up correctly between the two.
1967 Mustang Hardtop
Old build thread - SF
Current build thread - VMF
2013 Subaru BRZ
burnout289 is offline
post #4 of 22 (permalink) Old 04-09-2012, 08:07 PM Thread Starter
TrueBlue's Avatar
Yes, I checked the hole pattern against the old gaskets. It wants to start - you spin the key and VROOOOM! - but then it just dies off.
I adjusted the idle screws to 1.5 turns from seated and played from there, but no dice!
-Tom
2015 Ford F150 FX4
TrueBlue is offline
post #5 of 22 (permalink) Old 04-09-2012, 08:28 PM
Alan _MacDougall's Avatar
Fellow Sabres fan... When you look down the venturi and open the butterfly does it spray gas? If you have a PCV is the tube hooked up?
Alan _MacDougall is offline
post #6 of 22 (permalink) Old 04-10-2012, 08:41 AM Thread Starter
TrueBlue's Avatar
Hi Alan! Yessir, PCV valve is hooked up, and the valve rattles when you shake it. The throttle is indeed squirting gas down the throat.
Rough year to be a Sabres fan, eh?
-Tom
2015 Ford F150 FX4
TrueBlue is offline
post #7 of 22 (permalink) Old 04-10-2012, 10:11 AM
Another tough year for the Sabres. I still watched all the games on center ice. I expect Boyes and Roy to be gone but we need more than a player change.
If the float level is correct, I would take it off and start dismantling. I think its a gas delivery problem. I had a problem one time where there was a small pin hole in the rubber gas line, the car started but would stall shortly there after. Alan
post #8 of 22 (permalink) Old 04-11-2012, 09:49 AM Thread Starter
TrueBlue's Avatar
I set the floats at the time of rebuild, flipped the tanks upside down and adjusted them to sit level. There's a procedure to adjust them while the car's running, but since I can't get it to do more than fire and turn over, I can't accurately adjust that, either.
I'm just trying to knock down all the possibilities before I yank the carb off again. No big deal to do it but I'm just wondering if it's in the adjustments.
-Tom
2015 Ford F150 FX4
TrueBlue is offline
post #9 of 22 (permalink) Old 04-11-2012, 11:22 AM
Monzy's Avatar
What made you rebuild the carb? Was it running before the rebuild? Is there no way to keep the car running even with the throttle down? Does the 4160 have a sight to check float level? When it stalls out does it smell like gas? Are the venturies wet with fuel when it stalls?
Monzy is offline
post #10 of 22 (permalink) Old 04-11-2012, 12:43 PM
What was the reason for the rebuild? Did the carb sit for a long time with fuel in it? Was there anything else you did besides install the rebuild kit? Did you soak the main body in solvent to clean out the passages? Your float level should be close with your dry adjustment method. I would still try to check the sight hole for the proper gas level. Is your gas filter old?
post #11 of 22 (permalink) Old 04-12-2012, 03:13 PM Thread Starter
TrueBlue's Avatar
I rebuilt the carb as I was having hard starts - I'd have to pump the gas pedal and even crack the throttle open to start the car, and upon hard acceleration there was a noticeable delay.
Nope, no way to keep the car running without mashing the gas to the floor. 4160 does have two sight ports, but I can't seem to tell if the floats are level with the carb bolted in, how do you do this? Even with a mirror and lighting it looks (looks) like the float in front is slightly high, and the one in rear slightly lower.
It actually "puffs" fuel back out of the carb after I try starting it now. I didn't do any other changes to the car, just the rebuild, and the filter is not even a year old. Carb body, metering block, and the empty float bowls were bathed overnight in thinner, scrubbed, and blew clean.
I looked at the old gaskets lat night, they have locating holes to prevent them from being installed backwards, so I honestly don't think I could have installed something backwards.
I just can't believe I'm so far off. She won't even start now, just spins and puffs out the carb, as if to spite me.
-Tom
2015 Ford F150 FX4
TrueBlue is offline
post #12 of 22 (permalink) Old 04-12-2012, 03:40 PM
6t9mach1's Avatar
Sounds like its way too rich. Maybe your metering block is not true and the gasket is not sealing causing a crossing of the metering circuits? Perhaps a bad needle? Do you have any fuel coming out of the vent tube?
~Ryan~
1969 Mach 1- 357w: 11:1 compression, ported Canfield heads, FTI billet solid roller cam, Vic Jr., 850 Mighty Demon
Full manual AODE transmission w/ 9.5" Art Carr converter; 4.11 detroit locker
http://www.cardomain.com/ride/2554478
6t9mach1 is offline
post #13 of 22 (permalink) Old 04-12-2012, 10:37 PM
Monzy's Avatar
Sounds like the float needle shutoff is bad or the floats are not adjusted properly. You need someone cranking the motor and you lookings at the carb without putting your face right over the thing as it could ignite and take some hairs off so have a fire extinguisher handy. You shouldn't see gas pouring out of anywhere when the motor is cranked.
Take the sight plugs out when cranking and if gas comes out then the floats are to high and flood the motor out.
Monzy is offline
post #14 of 22 (permalink) Old 04-13-2012, 04:10 PM Thread Starter
TrueBlue's Avatar
I didn't see any fuel coming out of the vent tube. The float needles are the new needles straight from Holley. With it puffing gas out, it sounds like I am rich, but wouldn't it at least try to start with all that gas in the intake?
The rear float definitely had some gas coming out when the sight plugs were out. The front didn't though. Do you guys think my floats are sitting to high, causing the motor to just flood straight out?
I'm going to double and triple check wiring too, it's just not making any sense to me.
-Tom
2015 Ford F150 FX4
TrueBlue is offline
post #15 of 22 (permalink) Old 04-13-2012, 08:39 PM
Monzy's Avatar
No gas should come out of the sight plug if it does then adjust the float so it doesn't. If the float is low then adjust so fuel can fill the bowl.
If your flooding, you've got to open the carb up all the way to make it start by pushing the pedal down to the floor. Its very unlikely your going to start the motor if its flooded without opening the butterflies.
Did you touch the timing at all? Touch anything with the ignition?
Monzy is offline
