1966 Mustang needs a little work - Vintage Mustang Forums
Old 08-21-2012, 06:13 PM   #1 (permalink)
rusty428cj's Avatar
Default 1966 Mustang needs a little work
This project came in the other day for us to repair.
Rusty Gillis
Former SS/FA and SS/GA NHRA Record Holder
Gillis Performance Restorations
Port Richey, Fl
727-847-7973
www.gillisrestorations.com
rusty428cj is offline   Reply With Quote
Old 08-21-2012, 06:15 PM   #2 (permalink)
Fast68back's Avatar
Ouch! was the driver of the other car texting?
-Rick
IF YOU DON'T STAND BEHIND OUR TROOPS,
PLEASE, FEEL FREE TO STAND IN FRONT OF THEM
Fast68back is offline   Reply With Quote
Old 08-21-2012, 06:23 PM   #3 (permalink)
ylexot's Avatar
On the bright side there won't be any bondo in that lower rear when you are done.
Formerly of the Permanently Addicted...
Let it be known that I do not street race or condone that sort of thing
- unless the 'b@stard deserves it.
Someone takes his pants off and the rafters knock
Rock is dead they say
Long Live Rock!
67 conv. 289 4spd(mine), 67 coupe 289 Export(swmbo's)
ylexot is offline   Reply With Quote
Old 08-21-2012, 07:16 PM   #4 (permalink)
wow, thats awful but worth reapairing, its a stang
goyard74 is offline   Reply With Quote
Old 08-21-2012, 10:11 PM   #5 (permalink)
Insurance job? I'd love to hearing the squirming the company did to try and get out of fixing this.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 08-22-2012, 08:20 AM   #6 (permalink)
rusty428cj's Avatar
Hagerty insurance so far no problem. They gave him a check and know there will be a supplement. All they want is for me to send them pictures of the damaged they missed.
Rusty Gillis
Port Richey, Fl
727-847-7973
Old 08-22-2012, 11:17 AM   #7 (permalink)
Bleed Blue's Avatar
After the initial "ouch" reaction upon seeing the pictures, I started thinking about the driver of the mustang and what kind of whiplash they probably went thru. Those low-back seats are not exactly the hot ticket for safety. Hope they are ok.
Currently in my garage:
1966 Ford Mustang Coupe. 289 V8 w/5-speed.
2003 Ford Mustang Mach 1 w/mods
1998 Ford Ranger Supercab Flareside 4X4
2005 Ford Focus ST w/minor mods (daily driver)
2010 Ford Fusion Sport 3.5 (wife's daily driver)
Bleed Blue is offline   Reply With Quote
Old 08-22-2012, 12:14 PM   #8 (permalink)
rusty428cj's Avatar
The driver did have whiplash and his back is bothering him but he is back to work driving his FedEx truck. He is going with different seats either high back or head rests.
Rusty Gillis
Port Richey, Fl
727-847-7973
Old 08-22-2012, 01:05 PM   #9 (permalink)
NEFaurora's Avatar
I would have just taken the insurance money and run on that one. That car will never be the same no matter what. You should just drop the driveshaft, disconnect the rear brake lines, measure it out, and cut the car literally in half. I would not even try to start repairing that rear of the car... It's worthless anyway, so cut the car in half, Save time, trouble and money and once the rear end of the car is cut off while being on a frame straighetner, cut it in half, remove the rear end from the rear part of the car, and weld on a donor rear body from a junked or roller '65-'66 convertible...then move on with life..
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual
MCA#70001
NEFaurora is offline   Reply With Quote
Old 08-22-2012, 01:41 PM   #10 (permalink)
NAAAA.......
This is Rusty we are talking about. He will have it fixed in no time using all the original metal
Current: 67 Coupe 289
Former: 04 Mystichrome Cobra Vert
N2DAMYSTIC is offline   Reply With Quote
Old 08-22-2012, 01:48 PM   #11 (permalink)
correct way to fix is put it on a jig and pull it out as much as possible then cut and replace stuff .
1966 convert
click here for more pics
http://s147.photobucket.com/home/mikemstang66/index
mikemstang66 is offline   Reply With Quote
Old 08-23-2012, 03:33 PM   #12 (permalink)
rusty428cj's Avatar
One of the things that helped is he had a gas tank shield made for it and it also has subframe connectors.
Rusty Gillis
Port Richey, Fl
727-847-7973
Old 08-23-2012, 10:35 PM   #13 (permalink)
What are you talking about? This is an easy fix for an experienced body man with a good frame machine. Hell, it will be aligned better when done than it was when it left the factory.
You just pull everything back into place, and then cut out the damaged areas and install new panels.
Rusty, being what appears to have been a rear end collision, why is the owners insurance picking up the tab?
Let me guess, hit by someone without insurance?
Old 08-24-2012, 08:18 AM   #14 (permalink)
rusty428cj's Avatar
Women hit him got out asked if he was ok than drove off.
Rusty Gillis
Port Richey, Fl
727-847-7973
Old 11-03-2012, 11:08 AM   #15 (permalink)
rusty428cj's Avatar
We have not had a lot of time to work on this because of other projects. The parts came in.
The engine was removed
We moved it to the shop and started removing the suspension
Rusty Gillis
Port Richey, Fl
727-847-7973
