Electiric fuel pump issue... Please help - Vintage Mustang Forums
Old 11-30-2012, 02:16 PM   #1 (permalink)
Default Electiric fuel pump issue... Please help
Ok so I have been lurking around for a while before I decided to post something. I really need some help. I have a 64.5 w a 289 and a holley 4160 carb, inline universal electric fuel pump (5.5-9 lb output) w a adjustable pressure regulator. Here is the issue, I let the pump prime,try to start the car, flooded. Turn the pump off let it sit then use starter fluid and it fires right up. Turn the pun on while its running and almost instantly the engine dies... The carb has a new rebuild. Please help
Mooni is offline   Reply With Quote
Old 11-30-2012, 02:20 PM   #2 (permalink)
Turn the PUN on? What's pun?
I have an electric fuel pump and I have no issues. I prime it for 5-8 seconds, 0 to 2 pumps with the gas pedal (depending how cold or hot the engine is) and then fire it up.
what's your fuel pressure regulator set at?
1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row aluminum radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; Crager Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Curved Monte Carlo Bar.
My Life
Tarmac_69_Mustang is offline   Reply With Quote
Old 11-30-2012, 02:25 PM   #3 (permalink)
6 pounds
Old 11-30-2012, 02:35 PM   #4 (permalink)
I meant pump. Stupid spell check...I'm posting from my phone...
Old 11-30-2012, 03:00 PM   #5 (permalink)
crzyamerican's Avatar
Sounds like what mine was doing when I had a float needle sticking allowing the carb to overfill.
Early 1967 Coupe I6 restomod conversion
Completed:
I6 to 302 conversion (suspension, 8" rearend etc.), T5 Trans, Hydraulic clutch, power brakes, Front granada disc brakes, Aluminum Radiator, Electric Fan, HEI distributor, Headlight Relays, EZwire harness, New fuel tank, fuel lines, brake lines, Restored gauges, Shelby drop to many to list.
To do: Bodywork (done), install new interior
buy many more parts & pieces
More pics of work http://www.hubgarage.com/mygarage/cr...vehicles/34385
crzyamerican is offline   Reply With Quote
Old 11-30-2012, 03:48 PM   #6 (permalink)
I disassembled the float adjustment and the needle did have a little hesitation to open but not close.
Old 11-30-2012, 11:01 PM   #7 (permalink)
Your pressure regulator, or your pressure gauge?
Mine is set around 2.5 psi on the regulator and pushing 5.5 to 6 lbs on the gauge.
That's weird. I'm sure you did, but did you double check all the connections? Electrical and hoses?
My Life
Old 12-01-2012, 02:09 AM   #8 (permalink)
Tarmac, thanks for your time. The guage is attached directly to the regulator. To answer your second question, yes I have addressed all connections. I broke the carb down today again to check for any issues. I'm still in the works as far as that is concerned, I will post any findings. But in the mean time please help with any advice. I am a noob to carb tune/rebuild and any good advice will be a great help. Thanks
Old 12-01-2012, 03:13 AM   #9 (permalink)
Again, probably already done, but is the timing correct?
So, when it does fire up, does it stay on? Or does it fire up for a couple seconds then turn off?
My Life
Old 12-01-2012, 08:23 AM   #10 (permalink)
Lukesportsman's Avatar
If the car running/dieing is related to pump "ON", then it sounds directly related to psi. Can the regulator be turned down lower? Start at lowest setting and progressively turn it up. You may not be able to go beyond 5 psi. If its a stockish type build, it probably won't run bowls dry and this should help narrow down problem.
I recently bought an SU pump replacement for a pair of SU's. Switched from points style pump to solid state specifically designed for these low psi carbs. I now have an additional Quick Fuel regulator installed as fuel was pushed right out the overflows when ever pump was turned on. I ended up setting (apples to oranges, I know) down to 3.75psi to make it run "right".
Im betting on psi in reality being too high, no matter the current gauge output.
69 351 TKO Sport Roof
70 557 PG Mach I
67 347 TKO Coupe open track car
67 289 C4 Coupe cruiser
69 460 SCJ TKO convertible
94 351 TKO NASA Mustang
911 RS Tribute, 964 widebody, 993 twin turbo,73 911 rally, 70 914-8, 72 MGB, 67 MGBGT sbf, 67 XKE, 69 Buick GS, 02 Harley F150
http://www.hubgarage.com/mygarage/LukeSportsman
Lukesportsman is offline   Reply With Quote
Old 12-02-2012, 12:23 AM   #11 (permalink)
That is a good observation lukesporsman. I'll have to try that. I'll post the findings as soon as I get in the carb parts that I ordered.
Old 12-02-2012, 01:31 PM   #12 (permalink)
Default Fuel Pump
Off Track, but why not a mechanical pump?
jimeast is online now   Reply With Quote
Old 12-03-2012, 01:10 AM   #13 (permalink)
Not off track, it's how I purchased the car.
Old 12-03-2012, 08:00 AM   #14 (permalink)
Default Fuel Pump
and... why not a mechanical pump?
Old 12-03-2012, 08:18 AM   #15 (permalink)
chillininnh's Avatar
+1
I run a mechanical Edelbrock fuel pump, works great without the annoying noise.
69 Mach 1 418W/TKO600/Street HP750/RMP Front Coil-Over/TCP Manual R&P/3.70 Auburn Pro/Global West SFC-5 Leafs-Del-A-Lum/Koni's/Magnaflow 2.5 X pipe
http://s63.photobucket.com/albums/h127/chillininnh/
chillininnh is online now   Reply With Quote
