Building my car ('65 Coupe) for mix use, street and track.
What should I address first, the brakes or suspension?
Both are stock, with drums on all four corners.
The biggest issue I have with replacing the brakes is that I will more than likely have to buy new wheels and tires; I have 14"s up front and 15"s in the rear.
I need guidance. My grand ideas and wants are much larger than my wallet.
Thanks!
'65 Coupe - Trying to do it right the first time
if both are in equal condition, brakes. However, if your brakes are in good shape and suspension in poor shape, get the suspension up to snuff. Dead shocks and such can make the car very dangerous.
I agree, I would do brakes first. To go fast you have to be able to stop fast. If you plan for bigger wheels get the big brakes to fit. Horrible to run tiny rotors on bigger wheels. Ten get the new wheels/tires soon after. Shucks, that's one of the first things I swap out when I start a new project, any car.
It depends on what kind of suspension you want. If you go with a Mustang II style or RRS Macpherson Strut, they use a different spindle and thus a different brake. I personally hate both types, but thought I'd throw that out there.
A proper suspension setup will maximize your braking potential. Weight distribution, ride height, coilover spring rate, etc.
Around the same importance is tires. Without proper tire type and size you wont see very much of what your brakes are capable of.
Both kind of go hand in hand. Better brakes won't meant much if your tires suck and your weight distribution and spring rates suck.
I say get suspension, you'd be amazed at how much better it could make your current brake setup become. I came from M3s and track car setups; that's just my 2 cents.
1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row aluminum radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; Crager Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Curved Monte Carlo Bar.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
