Wheel size and offset? - Vintage Mustang Forums
Old 12-24-2012, 06:16 PM   #1 (permalink)
67WCoupe's Avatar
Default Wheel size and offset?
Will these work on my 67 coupe w/ 9inch...
17x8 - 4.75 BS
17x9.5 - 5.75 BS
I saw this setup on a 67 FB.
67 351W Coupe <--- FOR SALE
67WCoupe is offline   Reply With Quote
Old 12-24-2012, 06:55 PM   #2 (permalink)
Should if it's the same year. Same chassis size, right?
1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row aluminum radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; Crager Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Curved Monte Carlo Bar.
My Life
Tarmac_69_Mustang is offline   Reply With Quote
Old 12-24-2012, 07:26 PM   #3 (permalink)
Here is the VMF chart.
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
My cars, current and former.
- BluePrint Engines 347 Stroker, 400 HP, 421 lb. ft torque (On the Dyno & Installed)
- 4 speed Toploader
- Auto Meter gauges in the stock bezel
- American Autowire Installation (VMF & CJPP)
66FSTBCK is offline   Reply With Quote
Old 12-25-2012, 01:32 PM   #4 (permalink)
turbowars's Avatar
Is there a chart for 67?
Originally Posted by 66FSTBCK View Post
turbowars is offline   Reply With Quote
Old 12-25-2012, 05:22 PM   #5 (permalink)
j persons's Avatar
here's all of them:
Dodgestang Photo Archives
'97 TBird project. AED supercharger, forged bottom end. Runs high 11's, when it runs.
j persons is offline   Reply With Quote
Old 12-25-2012, 05:28 PM   #6 (permalink)
Sorry, linked to the wrong one.
- 4 speed Toploader
Old 12-26-2012, 09:31 AM   #7 (permalink)
67WCoupe's Avatar
Perfect! thank you!
Old 12-26-2012, 12:35 PM   #8 (permalink)
A 17X8 4.75bs on the front will most likely have the inner edge of the rim rub the end of the upper control arm. Trimming the control arm will allow it to work,or an 1/8" spacer*,its that close.
I have 18X8 with 5" bs and the rim is over the end of the control arm.
68 Mustang OpenTracker Control arms 1.5" Arning Drop 2005 GT front brakes*
*brakes may effect wheel placement.
that 4.75bs is going to be tight.
cyclone03 is offline   Reply With Quote
Old 12-26-2012, 12:42 PM   #9 (permalink)
67WCoupe's Avatar
So rears should clear?
Old 12-26-2012, 01:40 PM   #10 (permalink)
Rear.
I'm taking a deep breath here and saying ....maybe.
I have the same 18X8 5"bs front and back on my 68. 225/45 front 255/45 rears with the rear lowered about 1"-1 1/2" depending on who I'm parked next to. 13 1/4" from center of wheel to fender lip. Fenders well rolled,to flat. Both rear tires rub in the useual 67/68 spot. 2 o clock looking at the left fender,10 on the right with 160 lb in the back seat and a big hit(dip).
If your not sitting stock I think that extra 1/2" on that 9 1/2" wheel may cause you some trouble.
Look at it like this,on my 8" wheel I have 5" in with 3" out and at my ride hieght and tire size I cant go "out" at all.
You going 9.5 with 5.75 bs gives you 3.75" out without jacking it up or fender flares I think it will rub. The "problem" is that one spot on each side.
You can measure all this yourself it you have the car on the ground,just measure from the rim to the spring.Then ,with a strait edge,tire to rim and whatever doesn't clear a sweep of the strait edge. Then remove the tire and measure your back spacing.
It's not that hard once you look at the space.
Old 12-26-2012, 02:02 PM   #11 (permalink)
67WCoupe's Avatar
Rear.
I have a few buddies with DD mustang wheels on their newer stangs. I'm gonna see if I can borrow a front and rear wheel to test fit.
