is it possible to have hydraulic clutch master on the firewall with the booster on a 65 mustang? I have the mustangsteve power brake conversion on now. It looks like a smaller booster than the original booster. Does anybody have any pics of how this looks if it can be done?
I tried to make Modern Driveline's kit work with MustangSteve's power brake conversion. I couldn't get it to work; The hydraulic master cylinder just wouldn't clear the brake booster. I ended up scrapping the MS brake setup and going with a manual Cobra master cylinder instead. The brakes are awesome (I have Cobra 4-wheel disc brakes), but they definitely take more effort.
-Shannon
1965 Mustang convertible
331 Stroker with EFI, 355rwhp - 358 ft/lbs
Street or Track coil-over suspension
I made an under-dash assembly to mount the clutch master, like on 05+ Mustangs. I used the MS kit with an 89 4cyl Mustang booster. I think I remember seeing a thread where somebody used a hydraulic clutch with that booster. Try a search (no key word suggestions though).
__________________ Plain Jane 65 Coupe - Scary fast (at least that's what my wife says). (SOLD 10/2012)
Feature Car in December 2010 StreetScene (the magazine of the National Street Rod Assoc)
do you have any pics of your creation to maybe spark some ideas? what if you put a spacer on the left side of the clutch pedal to space out the clutch push rod away from the booster?
does any modifications have to be made when using the 87-93 fox booster for the clutch master to fit using the modern driveline kit or is it a direct bolt in?
The biggest issue I recall using the Fox 5.0 booster (in my '65) is that it moved the MC so far forward that it would no longer clear the stock export brace. This is a '94-95 Mustang GT MC so if you went with a smaller MC you may not have this issue but you will need to test fit it and find out.
I changed to the Street or Track billet export brace and it clears this MC just fine.
__________________ '65 A Code Coupe. 289, 10:1, Trick Flow TW 170 heads, Comp Cams XE266HR roller cam, T5Z spec, StreetorTrack front coilovers, Maier Racing leafs / SFC's / Panhard bar, Bilsteins, Steeroids rack and pinion, hydraulic clutch, 3.80 gears, Detroit Locker, 4 wheel discs.
'87 Foxbody AutoX C Prepared. Under the knife, again.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
