Need a custom efi fuel tank, who should i call? - Vintage Mustang Forums
Old 01-11-2013, 04:40 PM   #1 (permalink)
Default Need a custom efi fuel tank, who should i call?
Only heard of ricks tanks but the few times i called i wasnt speaking with anyone who knew much about mustangs or their tank designs. What manufactures can you guys suggest to call? I need to order one on monday.
55Speed is offline   Reply With Quote
Old 01-11-2013, 04:47 PM   #2 (permalink)
66resto's Avatar
Glenn's Performance...awesome tank and lots of options. Sweet 22 gallon sleeper tank. Just make sure to get the correct sending unit (1970).
I got mine there along with the complete fuel kit. He doesn't always get back to right away, but he's there...I don't think its a large outfit, so there isn't someone manning the phones 24/7.
I got the complete kit. Not sure if you need everything or just the tank. Extra $100 for stainless steel. If you want a kit, just pick one and he will just use the correct tank in the kit. Also, you can all black fittings which was a must for me...well, not a "must", but I didn't want the red/blue fittings.
I can get you some pics of mine if you want, but he has some pretty good pics on his site.
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
66resto is offline   Reply With Quote
Old 01-11-2013, 05:16 PM   #3 (permalink)
Tanks, Inc.
They have an awesome setup I'm ordering soon.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 01-11-2013, 05:20 PM   #4 (permalink)
Originally Posted by ScottsGT View Post
Tanks, Inc.
I called them a while back their tanks are not stainless and for my 70 the tank needs to be cut and welded etc to work. Not sure it makes sense i can do that tome one i have now i just want a bolt in deal with no modifications
Old 01-11-2013, 05:25 PM   #5 (permalink)
chillininnh's Avatar
If and when I switch to EFI I'd prefer the pump in the tank. I've been looking at the Aeromotive 18688 pump kit. I would pair it with a new 22 gal. fuel tank. Granted it's not inexpensive but cheaper than a custom tank like a Rick's.
Phantom Fuel System|Aeromotive
69 Mach 1 418W/TKO600/Street HP750/RMP Front Coil-Over/TCP Manual R&P/3.70 Auburn Pro/Global West SFC-5 Leafs-Del-A-Lum/Koni's/Magnaflow 2.5 X pipe
http://s63.photobucket.com/albums/h127/chillininnh/
chillininnh is offline   Reply With Quote
Old 01-11-2013, 06:28 PM   #6 (permalink)
wheelsup351's Avatar
Rick's Stainless Tanks : Welcome to Rickshotrods
Jason, traps 126 @ 3400# all motor
wheelsup351 is offline   Reply With Quote
Old 01-11-2013, 07:19 PM   #7 (permalink)
Oh crap. I want stainless too. Guess I'm back into searching again.
I like that Phantom setup, but I'm going to have to try and get over sticker shock before I consider pulling the trigger on that one. $550 and I still have to provide a tank.
Old 01-11-2013, 07:35 PM   #8 (permalink)
Originally Posted by wheelsup351 View Post
Does anyone have a ricks tank in their stang? Even they couldnt email me photos this is what worries me i want to see before i buy anything . Ricks mainly supplies. a ton of GM tanks. Detroit Speed was trying to get me to buy their tank and it is made by a colorado hot rod shop i think, then again no actual photos of this tank mounted in the car
Old 01-11-2013, 07:38 PM   #9 (permalink)
http://forums.vintage-mustang.com/4112621-post5.html
those tanks are really popular on the pro touring sites. i have seen one of his tanks in person and it's a stellar piece.
Old 01-11-2013, 07:40 PM   #10 (permalink)
DrStang's Avatar
These guys are very reasonably priced.
Hot Rod City
"A good friend will help you move. A great friend will help you move a dead body"
1965 A-Code Fastback
Built, September 14, 1964 (San Jose)
Viper red, G-Force T-5
TCP R&P, G Bar rear 4 link/w shockwaves
Global West Upper/Lower/Strut Rods
Ride-Tech Air ride
4 wheel Cobra disc brakes/Hydroboost
331 Stroker/Paxton Supercharger
Mass-Flo EFI
Owned since 1983
DrStang is offline   Reply With Quote
Old 01-11-2013, 07:59 PM   #11 (permalink)
Someone posted these guys, but I only made a note of it.
1971-73 Ford Mustang Fuel Tank
sanch052 is offline   Reply With Quote
Old 01-11-2013, 08:13 PM   #12 (permalink)
I thought the same thing but when you add up a tank ($400) and then you have to buy an external pump, then it's pretty close. I'm in the same boat. I have a brand new (stock) tank so it may be the best value for mine....
1968 Fastback Survivor car
1969 Mach 1 408
chatas1 is offline   Reply With Quote
Old 01-11-2013, 10:02 PM   #13 (permalink)
LastDeadLast's Avatar
That's my car in the link. The tank is a first class piece.
I had two install issues:
One: You have to drill your own mounting holes... and if you've ever tried to drill through stainless steel, you know what I'm talking about. I probably ruined 5 bits drilling the holes.
Two: The filler hole didn't match up to the 65 neck... I ended up cutting the filler next down a bit and finding a large flexible fuel host to span the distance.
I ran -6AN supply and return lines to the tank. All the connections, including the fuel sending unit is on top of the tank...
Here is a pick from last year:
-Shannon
1965 Mustang convertible
331 Stroker with EFI, 355rwhp - 358 ft/lbs
Street or Track coil-over suspension
LastDeadLast is offline   Reply With Quote
Old 01-11-2013, 10:43 PM   #14 (permalink)
Lukesportsman's Avatar
Phil,
I clicked on this initially to recommend the "guy" to contact you to buy your old fuel tank. LOL. Then to only realize your still searching. Among all the other costs your coming into I can only imagine the frustration. If it makes you feel a little better knowing that misery likes company. Check out the $2600 custom 911 fuel cells to be FIA legal.
Ill be reading your email in detail with response asap.
69 351 TKO Sport Roof
70 557 PG Mach I
67 347 TKO Coupe open track car
67 289 C4 Coupe cruiser
69 460 SCJ TKO convertible
94 351 TKO NASA Mustang
911 RS Tribute, 964 widebody, 993 twin turbo,73 911 rally, 70 914-8, 72 MGB, 67 MGBGT sbf, 67 XKE, 69 Buick GS, 02 Harley F150
http://www.hubgarage.com/mygarage/LukeSportsman
Lukesportsman is offline   Reply With Quote
Old 01-11-2013, 11:42 PM   #15 (permalink)
Build your own....
Installing 66 Gages in a 65 (ignore the title)
JamesW's Website
JamesWnew is offline   Reply With Quote
