Trick flow 170 question - Vintage Mustang Forums
Old 01-18-2013, 01:40 PM   #1 (permalink)
frdnut's Avatar
Default Trick flow 170 question
My brother just ordered a set of trick flow 170s..When he opened the box on the instructions it has a warning about piston to valve clearance..It says the 61 cc chambered heads work with stock pistons up to .550L and that the 58cc chambered heads require special pistons?....What would be the difference between the two heads that would affect PTV clearance differently?..I assumed the only difference would be a slightly smaller chamber on the 58cc version?
68 J code sprint, 408W with vic jr top end, Pro Systems 950HP Holley carb,Camshaft Innovations custom solid roller ,Hooker 6208s,Toploader,4:11 Detroit locker...
11.82@ 120.85mph
frdnut is online now   Reply With Quote
Old 01-18-2013, 02:09 PM   #2 (permalink)
rickgto's Avatar
Never used the 58cc version but I'm betting they're simply the 61cc heads milled to 58. If that's the case, PTV would be reduced by the amount they're milled. That said, I don't understand why they're rated at a certain (safe) max lift rather than lift at tdc they'd be safe at with stocklike pistons. Cam design/timing dictates in/ex lift at tdc moreso than a max lift figure.
rickgto is offline   Reply With Quote
Old 01-18-2013, 02:25 PM   #3 (permalink)
66resto's Avatar
Here is a thread with the 61cc head, F cam (512 max lift) (post no. 12) and still had to notch the pistons.
No matter what the combination is and whether are not it has been successful for others with the exact same parts...you always have to measure and it may or may not requiring notching after you get them in there.
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
66resto is online now   Reply With Quote
Old 01-18-2013, 02:44 PM   #4 (permalink)
Always clay the pistons when changing heads and/or cam. Cheap insurance and only takes a few minutes.
88cougargt is offline   Reply With Quote
Old 01-18-2013, 11:26 PM   #5 (permalink)
frdnut's Avatar
Yes I am thinking that must be the reason as well..Just seems odd to me that they would sell heads already milled down some..
11.82@ 120.85mph
Old 01-19-2013, 02:18 PM   #6 (permalink)
66resto's Avatar
Not everyone wants to run the same compression. Hard to make a universal aftermarket part for all the different combinations. You'll have more PTV issues with a inline head like AFR than you will ever had with this head.
Old 01-19-2013, 02:39 PM   #7 (permalink)
Trick flow... are all of their heads that "twisted wedge" design??
I think the special piston requirement is more of a result of the slightly different location of the intake valve as opposed to the combustion chamber size?
I could be wrong
Just my $.02...
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
a conglomeration of suspension parts and modifications that seems to work out, so I'm happy
TCP manual rack (love it)
VWW V45 wheels (like these too)
And a stupid cowl induction hood I should've never bought
blueovalfan68 is offline   Reply With Quote
Old 01-19-2013, 07:29 PM   #8 (permalink)
It depends on the cam you run - my understanding is you can run up to their stage 2 cam (cant remember the specs) without p/v issues on most stock pistons
I am running their 60cc TW heads on a late model explorer roller block with TFS stage 1 cam and no p/v issues
C0V3R is offline   Reply With Quote
Old 01-19-2013, 07:53 PM   #9 (permalink)
sportsroof69's Avatar
The twisted wedge heads give you better P to V clearance, than an inline head, even with stock pistons. That's why they're the only head that can use a 2.02 intake valve with the stock bottom end.
sportsroof69 is online now   Reply With Quote
Old 01-20-2013, 03:32 PM   #10 (permalink)
66resto's Avatar
It also makes a difference how far your piston is down the hole, if any. Measure or run the risk of having a very bad day.
Old 01-20-2013, 05:38 PM   #11 (permalink)
cornholio's Avatar
Another tidbit.... if those have the "high ports" you will need to have headers fabbed...
That is unless I am behind the times, and within the last 2 years someone started making a set that fits. They did not and I had to have a set made out of California from Ford Powertrain...
[SIGPIC]
1966 Coupe Restomod
331 stroker, 5 speed
Discs x 4, 9 inch with 4.10 posi
Coil Overs, Ladder bar setup, subs, 6pt rollbar
Dyno'd 400/430
cornholio is offline   Reply With Quote
Old 01-20-2013, 06:04 PM   #12 (permalink)
170 are not High Port heads so standard headers will work.
kwkenf is offline   Reply With Quote
Old 01-20-2013, 11:44 PM   #13 (permalink)
frdnut's Avatar
Yes I am fully aware we need to check the PTV clearance..I was just wondering what all the differences were between the two heads that trick flow felt the need to say one would need a different piston and the other was ok up to .550L
11.82@ 120.85mph
Old 01-21-2013, 09:19 AM   #14 (permalink)
I'm. It sure why trick flow gives a generic lift number like that. Duration actually has more to do with it than lift.
Old 01-22-2013, 08:41 AM   #15 (permalink)
cornholio's Avatar
Thats good. Man was that a pain.
[SIGPIC]
1966 Coupe Restomod
Dyno'd 400/430
