I have seen posted about Gilmer Belt Drive but no one has said how they like them. The pros and cons. Getting ready to buy one but wants some input. It would solve my power steering problem.
There are a few here with that set-up and it looks amazing, no slippage. Tho the belt would be special order if it ever broke, leaving you without the car for awhile.
The ones I have seen were not for power steering cars tho.
-Brett
1968 Mustang coupe 302
Getting ready for a 5.0 roller swap
Pros
- No slippage
- Low chance of throwing belts
- Noisy supercharger sound
Cons
- Cant get belts as easily if you throw them or strip teeth
- Not easy to setup for full set of accessories (alt/ps/wp/ac)
- Noisy supercharger sound with no supercharger
Whats your p/s problem and why would a gilmer drive sort it out?
This one has a V belt setup. I can get extra belts for $24.95 from a store on ebay. I don't have power steering but that is a future project. Its was removed when someone put a 429 in her.
I'm going to take a stab in the dark and say TS has a squealing belt issue and thinks a Gilmer drive will help. I've never been a fan of just tossing money at a problem so if i'm right about the noisy belt, give this a try: A) Tighten the belt B) if the belt is tight and still makes noise ensure it IS the belt and not a something else. With the car off, take a bar of soap and rub on the pulley contact portion of the belt. Start the car and if the noise doesn't stop then you have another problem. If the noise does not stop and it's not a pulley then check the belt alignment. If that is good, try a narrow(er) belt that fits in the pulley groove a little more snugly.
Restoring a 65 Mustang i've owned since i was 14...don't ask how old i am now.
Boom, without power steering. I don't have away to run the water pump. I would have to buy a MARCH 2V underdrive pulley for another $79.99. But for another $30.00 I can get the 351C gilmer setup.
Thanks for the pictures zstang. I will order the gilmer setup. Boom, maybe its just the MARCH setup but the alternator is 3/8s off center from the water pump and the crank.
Hmm there shouldn't be an alignment issue. I would double check the alt mounting forst. On my CVF set-up tjere are spacers thay need to be on a few bolts to align everything properly.
-Brett
Just keep in mind fan-to-radiator clearance when going with something like the Gilmer due to the width of the belts. Clearance is already pretty tight with the standard belts. You can get gilmer pulleys for cars with power steering, but they essentially have a v-belt groove at the back of the cog pulley to accommodate the PS belt. I don't think you can use these on an A/C car though.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
