Nice productivity. Look a lot stronger than most being sold. Will these go through floor like TinMan's or will these be entirely under floor board? From frame to frame in the air or will you have attachments to floor board?
69 351 TKO Sport Roof
70 557 PG Mach I
67 347 TKO Coupe open track car
67 289 C4 Coupe cruiser
69 460 SCJ TKO convertible
94 351 TKO NASA Mustang
Thanks guys, I'll be sure to post pics when I get them installed.
LUKESPORTSMAN: These will be completely under the floorboard. They slide inside of the front framerail and will be mounted to the bottom of the rear frame rail, they reach just below the leafspring mounting bolt. The 5 brackets that are welded to each one is where they get welded to the floorboard.
I think the floor board "tie in" is essential to adding torsional rigidity. Yes, please follow up posts during/after install.
70 557 PG Mach I
Nice work. I made my own some time back and thought about having brackets on the sides. Didn't like the "tacked on" look though. So I drilled holes in the pans and rosette welded the pans to the bars from the top.
Excellent fab work Jody Are you anywhere near York? Nice to see another Mustanger in South Central PA!! If you ever get bored and wanted to make another pair I would buy em from you! Kip
65 Fastback
302, Toploader, 3.0 open rear
4 wheel manual disks (SSBC Force 10)
Flaming River 16:1 steering, A/C, MSD ign.
Opentrackerracing roller perches, upper and lower control arms, roller idler
Street or Track adjustable strut rods, Edelbrock IAS shocks
I've been wanting to do alot of mods like this to this car but I had been usually building stuff for customers and by the time I was finished with their stuff I really didn't have the ambition to work on my own. I haven't been doing much fab work for others lately so I'm finally in the mood to work on my own stuff. I want to make a set of adjustable strut rods and build a simple coil over set-up for the front yet, hopefully I have that done and the engine back in by spring time cause I'm feeling THE NEED FOR SPEED!!
TB350, I'm in Chambersburg. Don't know if your into dirt latemodel racing or not but if you look at the pictures on my garage wall you can see a racing hotshoe from York.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
