Camber eccentric bracket replacement - Vintage Mustang Forums
Old 01-28-2013, 07:42 AM   #1 (permalink)
Default Camber eccentric bracket replacement
My camber adjuster bracket (square piece with ears bent up on each side) is hosed up from people trying to adjust it with the wheels on the ground. How is this bracket attached to the frame? How is it replaced?
Jsams is offline   Reply With Quote
Old 01-28-2013, 10:22 AM   #2 (permalink)
Just some guy
GypsyR's Avatar
It's pretty firmly welded to the frame. The easy way out would be to install a eccentric eliminators. With them you wouldn't have to worry about the ears being bent. They are nice to have anyway. I have had mine knocked out of place after hitting a good bump or pothole. Very annoying.
First eliminator kit I searched up-
Mustang Eccentric Eliminator
GypsyR is offline   Reply With Quote
Old 01-28-2013, 12:06 PM   #3 (permalink)
Can't I just tack the eccentric in place?
Old 01-28-2013, 02:15 PM   #4 (permalink)
Just some guy
GypsyR's Avatar
Old school. Back before there were eccentric eliminator kits people indeed often tacked them into position.
Old 01-28-2013, 08:33 PM   #5 (permalink)
If the bracket ears are bent, how is the eccentric eliminator held in place?
Old 02-11-2013, 04:19 PM   #6 (permalink)
Anyone else with this issue?
Old 02-14-2013, 03:56 PM   #7 (permalink)
your "ears" would have to be VERY bent... flat almost to not work with the eccentric eliminator kits. just heat it up and gently hammer the ears back and bolt in a eccentric eliminator kit.
67 fastback
67 coupe (sold)
68 coupe (sold)
64.5 vert
roboticservo is offline   Reply With Quote
Old 02-15-2013, 08:23 AM   #8 (permalink)
buening's Avatar
Got a picture? This will help us visualize how messed up they are. I'd try to straighten it up with some vice grips to straighten the ears and a hammer to get the bracket to lay flat. Then get the camber eccentric eliminators. Keep in mind those eccentric bolts don't hold an alignment for crap if you drive on some rougher roads. The eliminators lock it into place.
They do sell new brackets to replace your current ones. You'd have to get a spotweld driller or use a air hammer with chisel to get the old one off.
70 Mach 1 - 351w/T-56
70 SportsRoof - 302/C4
05 F150 FX4
06 BMW 530xi
T56 Conversion Thread
Custom Motor Mount Build Thread
buening is offline   Reply With Quote
Old 02-15-2013, 10:02 AM   #9 (permalink)
I am out of town right now. Ill post some pictures on Monday.
I do think they could be fixed with a torch. One problem is the tee sump oil pan limits hammer access.
Who makes the best eccentric eliminator kit? I notice some offer a finer range of adjustment
Opentracker seems to have the finest (5 position) adjustment
Old 02-15-2013, 11:21 AM   #10 (permalink)
If you need to replace the bracket, Mustangs Plus sells them.
https://www.mustangsplus.com/xcart/1...c-Bracket.html
Our camber kit has 9 positions.
www.opentrackerracingproducts.com
__/___________\__
O[[[_________]]]O
l__\o---------o/__l
opentracker is offline   Reply With Quote
Old 02-15-2013, 11:51 AM   #11 (permalink)
Ok I just bought john's kit from his website.
